2002 civic sputtering/hesitation
I have a 2002 honda civic ex that is sputtering or hesitant apone slow acceleraton and when driving slow. It only does this when I'm driving slow or accelerating slow . I do have a cel p1491 egr valve insufficient lift. I just changed my plugs and o2 sensors. Any ideas?
I just did that last week because I had a insufficient flow code for the egr. Now I have code 1491. I suppose I will take it apart again next week.
take off the EGR assembly which is on the passenger side near the valve cover. it's held on by 2 nuts. spray the nuts with pb blaster first. Clean the EGR valve and port with carb spray/cleaner. also, buy a can of sea foam cleaner.
Last week when I did the o2 sensors and spark plugs I took off the intake and cleaned the chambers and egr valve. I use to have a insufficient flow code but that went away now I have p1491. I ran seafoam through it just a bit ago and the code and hesitation are still there.
no, you don't want to take off the intake manifold.
Likely needs a new EGR valve, too. But a thorough cleaning of the EGR system might do it.
I have all week off next week so I plan to take it off again. The intake gasket is two peices one is metalic and the other black which way does it go on?
Before doing all that work removing the intake, i would take off the iac. Clean, replace it along with the VTEC if you have the EX. Put a whole bottle of Red Line Fuel Injector cleaner in the tank, it's expensive but it's good stuff.
tortis
Jul 4, 2015 10:06 PM
