ID injector fitment
Old Feb 14, 2013 | 11:51 AM
eriki's Avatar
Default ID injector fitment
I'm having issues with my ID 1000cc injectors, every time I want to put them in on the cushion it just wants to fall through it. Or if I carefully get them to sit in the cushion it makes my fuel rail too high to bolt it. Here's some pics to show what I'm dealing with and hopefuly some one can chime in. Oh and btw I got these injectors used from a member so if I am missing anything let me know.
Attachment 310477
Old Feb 14, 2013 | 11:57 AM
accorse07's Avatar
Default Re: ID injector fitment
Your going to want the rubber injector washer to sit past the o-ring. What do you mean by makes your fuel rail too high to bolt in? A picture of that would be much better than what you posted.
Old Feb 14, 2013 | 12:36 PM
eriki's Avatar
Size:  136.1 KBSorry I was trying to do this from my phone but how I have it in the pic makes the fuel rail sit too high past the studs.
Is this what u mean by past the O ring
Old Feb 14, 2013 | 12:37 PM
eriki's Avatar
Old Feb 14, 2013 | 12:41 PM
eriki's Avatar
This does not work because when I put the fuel ra in it pushes the injector in and I don't like the idea if the O ring being past the cushion and get sucked in the motor
Old Feb 14, 2013 | 02:38 PM
eriki's Avatar
Bump
Old Feb 15, 2013 | 05:11 AM
eriki's Avatar
bump any one?
Old Jan 30, 2014 | 04:53 PM
JdmTosca's Avatar
Had the same issue today when I swapped mine used the same rubber grommet and either sits up top or all the way in and wobbles, tomorrow im going to check for bigger size o ring, and info on yours ?
Old Jan 30, 2014 | 05:30 PM
southbay's Avatar
Originally Posted by eriki
Attachment 310483Sorry I was trying to do this from my phone but how I have it in the pic makes the fuel rail sit too high past the studs.
Frist off there is no need for the bottom o-ring. What you are missing is a collar that fits on top of the bottom seal. This collar keeps the seal from riding up on the injector. Hope this helps,
Old Jan 31, 2014 | 01:05 AM
JdmTosca's Avatar
Where can this collar be purchased ? Thanks
Old Jan 31, 2014 | 08:41 AM
southbay's Avatar
We can't sell them to you because we are not vendors on this forum, however if you want I'll help you out and give you a set one car guy to another.
10sec4door
Jul 11, 2010 08:46 AM
DC206R
May 24, 2009 10:55 PM
svacca1
Sep 7, 2007 09:41 AM
jabroni95gsr
Apr 15, 2003 05:05 AM
