Ef wiring problem??
Old Feb 12, 2013 | 11:00 AM
onesikgsr's Avatar
Icon2 Ef wiring problem??
I have a 88 civic sedan with a d16z6 swap. I was using boomslang wiring harness but ran into some problems with that harness with the car not starting. So i decided to upgrade to the chasebays harness which i have installed. Only thing is now that i have it installed it doesn't want to hold an idle and has a check engine code of 20 which is the electronic load detector. Its running on a p28 a02. I've checked all the grounds and everything is good. Lost on what else to do. Any help would be much appreciated.
Thanks,
matt
Old Feb 13, 2013 | 01:34 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ef wiring problem??
What engine bay fuse box are you useing?
The ELD is mounted to the underside of the engine fuse box, the 88 does not have an ELD. 94
Old Feb 13, 2013 | 11:46 PM
pizzamann132's Avatar
What he said^^
Old Feb 17, 2013 | 01:04 PM
mn6107's Avatar
Ef obd0 is nothing but troubles
Old Feb 18, 2013 | 05:39 PM
Hectamoan's Avatar
Agreed
Old Feb 20, 2013 | 03:40 PM
onesikgsr's Avatar
Im using the stock fusebox. In my 88 helms manual it says it has a ELD.
Old Feb 22, 2013 | 05:24 PM
onesikgsr's Avatar
Chasebays doesnt use the eld wire to the ecu in their harness. Is this needed to run the car properly?
slob20ef
Jun 25, 2012 08:04 PM
sepetinswenze
Nov 25, 2010 05:25 AM
MPF_supra
Mar 14, 2004 02:43 PM
