fs white 97 ek coupe
i have a 97 white ek coupe for sale ( no rust) 3500 obo.
++++WILL HAVE PICS UP IN A FEW MIN WHEN THEY UPLOAD++++
has 140,000 original miles on both the engine and chassis.
motor d16y8
-had these parts installed about 20,000 miles ago
-water pump
-oil pump
-timing belt
-timing belt tensioner and spring
-cam seal
-vtec solenoid gasket
-oil pan gasket
-valve cover gasket and spark plug seals
-new exedy stage 1 clutch (grabs nicely)
-oem flywheel was turned
-it is lowered on eibach springs
has some 16 inch aftermarket wheels and 80% tread on tires
-has a poly front lip and rear lip
-some raspy exhaust
-and ebay header
-trans does not grind in any gear and shifts very smoothly
-fluids were always checked and do not leak.
-block has oil on it from previous owner not caring about the oil leaking from seals
driver side
driver side
rear
inside
inside
passenger side
motor
262 995 8080
2300 firm
motor d16y8
-water pump
-oil pump
-timing belt
-cam seal
-oil pan gasket
-some raspy exhaust
-and ebay header
driver side
driver side
rear
inside
inside
passenger side
motor
262 995 8080
2300 firm
raverx3m
Dec 27, 2011 02:13 AM
