which fuel pump, and other ?
Old Feb 8, 2013 | 02:50 PM
wasp9166's Avatar
Default which fuel pump, and other ?
91 civic dx 214k, just stopped running today, i suspect the coil or ignitor in dizzy finally crapped out, i had bought a cardone dizzy but decided not to put it in when i did the timing belt in october
if it was the belt skipping, i would think it would have done it long before feb since i did the belt job in oct
main relay is only a few years old
so, i'm going to throw in dizzy tomm
as long as i line up offset groove should be no need to pull cap and look at rotor correct?
and if it still doesn't start i suspect the fuel pump, i also have no codes
can the fuel pump be installed from under seat without dropping tank?
and what pump would you recommend if it gets to it
tia
Old Feb 8, 2013 | 02:53 PM
wasp9166's Avatar
Default Re: which fuel pump, and other ?
btw, when i turn it over i will get one pop from tailpipe during cranking, that's it
slight backfire kinda, but it's muffled, only in very beginning of cranking
Old Feb 9, 2013 | 07:50 AM
wasp9166's Avatar
dizzy in, done
thanx for your thoughts you 79
Old Feb 11, 2013 | 05:46 AM
wasp9166's Avatar
car ran good after install but idle was rough
pulled ecu fuse, seems all good now
does ecu have to learn new dizzy ? seems maybe it had erroneous parameters in memory from old dizzy?
what external tach should i get to set base idle?
poidude
Aug 13, 2012 12:13 AM
Deano_d
14
Nov 28, 2009 08:54 AM
Chef Andre
Oct 17, 2008 12:19 PM
Kommodity
Sep 4, 2005 11:10 PM
