Fuel Pump Issues!!!!!! Please Help!!!!!!
Ok just to give you a little history i have a 2000 Honda Civic Ex.... mileage is up at about 82-85,000. Being that the mileage is where it is I knew it was time for some service. One day while i was driving i was cruising, shifted to 3rd gear and the car stalled out. My car did not start for 30 mins there after. I got it to a local shop and got all my belts changed out, as i had symoptoms of this needing to be done prior to the incident. Now after the timing belt was changed my fuel pump started squeeling.... and the car started sputtering. After a couple of weeks of me telling myself it was time for the pump the be changed... my car wouldnt start. So i bought the fuel pump and changed it out. Now the car wont start. It cranks and turns over but wont fire.....any suggestions?
Re: Fuel Pump Issues!!!!!! Please Help!!!!!! (Kommodity)
Is your pump even coming on. Turn the key to the on position do u hear it whinning if not then check the wires to the pump then check your fuel pump relay.
Re: Fuel Pump Issues!!!!!! Please Help!!!!!! (JUMPTHELIGHT)
I had that issue right now. Sometimes it just wouldnt start. I dont even hear my fuel pump turn on. Keep trying and it will eventually fire right up!
Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">check main relay (by hood latch under driver's dash)</TD></TR></TABLE>
wrong he has a 2000 civic the main relay is behind your glove box, to the far right corner...
AZ accord
09-10-2015 03:24 PM
