B16 Turbo... 9.0 Compressiong or go higher?
Old Feb 7, 2013 | 09:55 PM
CRXherbie91's Avatar
Default B16 Turbo... 9.0 Compressiong or go higher?
I have a built b16 turbo a clutch away from being dropped into the car, its a 81.5 bore with 9:0 compression CP's.. .Should i stick to that compression, or go up to 10 or 11:0 ... alot of people say high compression an boost dont go good together.. i believe its fine depending mainly on tune, but also high how your talking... oh yea, also will be on 93 octane gas, i know that means alot too.. i have heard peole having trouble with over 12.5 compression on all motor pump what is your take on this...
is it worth upgrading the pistons this far along? ... is 9:0 perfect and have risks with higher compression? or should i just leave it since im this far along, and save it for when/if it blows up.?
Old Feb 7, 2013 | 10:05 PM
Spawne32's Avatar
Default Re: B16 Turbo... 9.0 Compressiong or go higher?
who said high compression and boost dont go together? muckman is like our poster boy here as to how far high compression engines can go with boost, and beyond. I would say you would be fine up to 11:1 on 93 pump gas. Anything beyond that and you will have to compromise by retarding the ignition timing alot more. But if you have the 9.0 pistons and the motor is assembled and ready to roll, no reason to change them.
Old Feb 7, 2013 | 10:25 PM
wantboost's Avatar
Who is Mr Robot?
Under boost, I wouldn't go 11:1 without methanol injection, dynamic compression is just way too high with any reasonable boost levels.
For straight 93 with no other power adders, 10:1 is the limit
But if your motor is already built why take it apart. 9:1 will work just fine
And you haven't even given a power goal
Old Feb 7, 2013 | 11:59 PM
yea, i thought 11:0 would be the MAX but i dont want to retard my timing alot of people say low compression and at the time of building motor i was doing research and 9 seemed to be about right, its stock sleeves, my tuner dont want to go past 450 with stock sleeves, in your opinion what do you think stock sleeves will hold reliably on 93? .. and also about compression, i was thinking if i were to switch out, or rebuild, i was thinking like 10.0 compression, right now like i said its 9 compression, but i have a gsr head on it, i believe it bumps it up a few point, and both the head an block are resurfaced i doubt that matters how little gets taken off in the process... how much comp does the gsr head bump it up? .. and if i want to add a few points to get it closer to 10, or even at or beyond, what kind of thoughts do you have on chaning to flat valves, thinner head gasket or both? .. thats easier process, headgasket being the easiest, as i plan on pulling of the valve cover and cams out to make sure there is enough assembly lube on it, an either way add more to be safe.. i may keep it the same, but i may consider a thinner head gasket, im thinking with a 2 or 1 layer and the gsr head, it should be at least 9.6 or even closer if not 10..
Old Feb 8, 2013 | 12:29 AM
chrisDavidson's Avatar
with 10.1, thats what i run on 30lbs with meth, never had problem. All in the tune.
Old Feb 8, 2013 | 09:44 AM
boosted_D's Avatar
There is no need for all this speculation on what could be better.
9:1 on a turbo motor is great, dont waste your time or money trying to change things now, its already done.
Do not try to bump compression by using a thinner headgasket, this is pointless and will cause nothing but HG troubles, use an oem honda HG.
Your motor will handle 450 whp on 93 pump with forged internals, as long as you have the right turbo/fuel/tune setup.
450whp is pushing the limits of 93 pump gas and the stock sleeves though, will it work? yes, would 400whp be safer? yes.
Old Feb 8, 2013 | 10:05 AM
mar778c's Avatar
Community Builder
Community Influencer
11:1 is no problem but it depends on more than just fuel. Cams, piston, and the tune play a significant role.
Higher compression will make engine more responsive at virtually any level of boost.
Old Feb 8, 2013 | 01:26 PM
wantboost's Avatar
Who is Mr Robot?
Like I said, in general 10:1 is the rough limit for a setup using straight 93... anything above that and you ave issues.... such as flame front travel across the domes, which can cause detonation.
Not to mention you need a pretty healthy ignition system to deal with spark on a high compression motor... you can't simply gap the plugs down. It takes a lot of energy to ignite a mixture under that much pressure without blowing the spark out.
Old Feb 8, 2013 | 03:38 PM
mar778c's Avatar
Community Builder
See link below
https://honda-tech.com/forums/forced-induction-16/high-compression-low-boost-2999654/
This topic has been discussed many times. 11:1 is not a problem with the right setup. Also, I made 425 whp with a Holset turbo, 14 lbs of boost 93 octane. Natural Aspirations made 475 whp with a 5858 on 93 octane. You can check those builds for more details. They were b18c1 builds.
Old Feb 8, 2013 | 04:11 PM
rydinsolo's Avatar
Good info in here. Kind of helps me as well as next winter i will be doing a full build but im getting the b16 block sleeved. Right now im on a completely stock motor, head, tb i do how ever have itr cams. Makes 315whp on 8lbs. As soon as i finish swapping the motor into the da shell im going to get retuned up to 14lbs. Looking to get as close as i csn to 400whp on completely stock motor minus itr cams and srp headstuds..im also running a 50trim turbonetics with rc440's and wapbro 255 on 93oct.
Old Feb 8, 2013 | 04:41 PM
mar778c's Avatar
Community Builder
^^^rc440 will not make it to 400 whp safely.
Old Feb 8, 2013 | 04:56 PM
rydinsolo's Avatar
I know thats what im running currently. Getting new ones to bring down to the tuner. Will get installed there and retuned
Old Feb 8, 2013 | 05:03 PM
wantboost's Avatar
Who is Mr Robot?
They won't even make it near 350, much less 400
Old Feb 8, 2013 | 05:23 PM
rydinsolo's Avatar
Well im only at 315 now with them. And they were on the last motor that made 328
Old Feb 8, 2013 | 05:31 PM
94civicgsr's Avatar
if im not mistaken i would uprade the injectors cause your about to max them out. go with some bosch ids they are very consistent and dont need a resistor
Old Feb 8, 2013 | 05:53 PM
wantboost's Avatar
Who is Mr Robot?
Anything above 80% duty cycle is bad for an injector... and you're right at that line
Old Feb 9, 2013 | 03:46 AM
blackeg's Avatar
while you can absolutely go into the 10's static compression, for pump gas 93 octane id keep it between 9 and 10. my car for example is about 10:1 (9.7:1 cp plus head and block resurfaced). it is fine but i wouldnt want more than that. you gotta trade longevity and reliability for a bit of responsiveness. you have to take other factors into consideration, bad gas, increased heat during hot days etc, you really just want a slight buffer for peace of mind.
Old Feb 9, 2013 | 07:36 AM
rydinsolo's Avatar
if i was to buy rc 1000's that would be good? i plan on going bigger during next winter (sleeved block bigger turbo) so would the 1000's be ok for me now and just tune them down?
Old Feb 9, 2013 | 07:39 AM
mar778c's Avatar
Community Builder
As someone else said, ID 1000s are the way to go.
Old Feb 9, 2013 | 07:47 AM
rydinsolo's Avatar
thanks will be ordering them soon.
Old Feb 9, 2013 | 11:57 AM
boosted_D's Avatar
AGAIN.... because the motor is already done, you are wasting time and money for no reason.
If you want 400-450 whp 9:1 will get you there just the same as 10:1 or 11:1
If the motor wasnt already built with 9:1 it would be worth thinking about, but its already done.
The only feasable way to make it higher c/r is to pull it back apart and swap to higher c/r pistons.
So your going to spend how much time, and the cost of a new HG, and new pistons for what? Its a waste.
Old Feb 9, 2013 | 12:24 PM
mar778c's Avatar
Community Builder
^^^WTH are you posting about? Read the thread, seriously.
Old Feb 11, 2013 | 07:37 PM
94civicgsr's Avatar
Some people dont read all the way through but anyway good choice with taking our advice with the bosch injectors you will be very pleased with the consistancy they provide for tuning.
MiKeAhOwSkI
May 20, 2005 09:36 AM
Simple
Nov 10, 2004 07:45 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
B18C Hatch
Sep 17, 2003 05:41 PM
s0liDyNe
Jul 19, 2003 10:24 PM
