alternator wont charge my battery, but why? need help asap.
Old Feb 5, 2013 | 12:13 PM
dsm duster's Avatar
Icon3 alternator wont charge my battery, but why? need help asap.
while driving the other night my radio, lights, tach, and speedo all went out one right after the next. i just figured my alternator went out so i changed it and nothing changed. so i brought my battery and my original alternator in to get tested and they both passed. i have also checked my fuses under the hood and there all good. the only thing i can think of is the wires running from the alternator but i cant see a thick 8 gauge wire just breaking... I'm very confused right now any help would be much appreciated this is my daily and i need it running again asap...
Old Feb 5, 2013 | 03:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: alternator wont charge my battery, but why? need help asap.
Make sure alt. "exciter" lead has power when ign. switch is on.
Check for voltage on the thick lead, ["8gauge"] at the alt. with ign. switch off, it should be the same as batt. voltage, ifr not check your main fuses. 94
Old Feb 5, 2013 | 07:34 PM
dsm duster's Avatar
ok thanks for the advice. i get power from the alt depending on how the wire is moved so that's why im thinking something is messing up in that 8 gauge wire. so im gonna just get a new wire and run it from the alt to the batt and see if it works.
Old Feb 5, 2013 | 09:27 PM
TCE_4BangN's Avatar
I had a similar problem with a Del Sol I had. Turns out the guy I bought the car from swapped the battery wire and the ALT wire in the fuse box in order to make the car run when I picked it up. Shifty ****** he was. Turned out that the ALT worked fine.
Old Feb 7, 2013 | 12:15 PM
dsm duster's Avatar
Yeah i just put a new 8 gauge wire in and it works fine now. I think they had to extend the wire when they did the H22 swap so im guessing it broke where they spliced it together.
courtney42
Other Make Vehicles
Aug 13, 2009 05:07 PM
949
Aug 2, 2008 03:59 PM
tcs8ter
Jan 1, 2008 03:22 PM
JdmEG6Si
Dec 30, 2007 08:30 PM
chad174
11
Apr 18, 2003 09:40 AM
