D16Y7/D16Z6 Mini-Me headbolts
Old Feb 1, 2013 | 01:47 PM
94EG8's Avatar
Seagull Management
Default D16Y7/D16Z6 Mini-Me headbolts
Can someone please explain the logic of running one Z6 bolt at the back next to vtec solenoid? The holes are all the same depth, and both engines use headbolts that are all the same length (the length between the two engines is different) I just don't understand the reasoning here at all.
Old Feb 1, 2013 | 02:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: D16Y7/D16Z6 Mini-Me headbolts
Wondering why myself now. I've read that in quite a few write-ups but then read twice as many more that never brought it up as an issue to run the same bolts all the way around.
Old Feb 1, 2013 | 07:44 PM
94EG8's Avatar
Seagull Management
I figured it out. That back hole next to the vtec solenoid is raise in the Z6 head by a fair bit. I can only assume the other 9 holes in the Z6 block are drilled deeper to allow for the longer bolts on those holes.
In other news I got it all put together and the head as a bent valve, wonderful. Gonna try some really ghetto straightening techniques tomorrow and see if I can get it straight enough to stop binding.
Old Feb 1, 2013 | 08:02 PM
jbpnoman's Avatar
No pick and pulls near you? I was just walking through one today, and there was at least a dozen Z6 and B7 heads laying around.
Old Feb 2, 2013 | 03:59 AM
94EG8's Avatar
Seagull Management
About an hour away. I have valves here. I just don't have another headgasket and this has to be in and running by tomorrow.
Old Feb 2, 2013 | 06:42 AM
apexi_rsx's Avatar
trying to rebend that valve probably isnt going to work. but goodluck. they are made of stainless steel and dont bent very easily. it has to seat perfect or ur gonna get a tap and probably wear the valve seat out
Old Feb 2, 2013 | 08:15 PM
94EG8's Avatar
Seagull Management
Screwdriver and hammer actually worked. I couldn't believe it. I'm not even so sure it was bent as it was stuck from sitting. I just hit it a couple of times and it stopped snapping. Just had it running a few minutes ago and it's smooth and quiet.
hoya_10fintec
25
May 26, 2020 08:40 AM
KodSol
Jul 6, 2012 01:26 PM
93turbo16
Mar 19, 2012 11:38 AM
zacattack18
17
May 11, 2009 10:03 AM
