should there be a gasket between manifold and turbo ?
Old Oct 20, 2002 | 10:13 PM
cokex's Avatar
Default should there be a gasket between manifold and turbo ?
just wondering ..
Old Oct 20, 2002 | 10:21 PM
The Shodan's Avatar
Default Re: should there be a gasket between manifold and turbo ? (cokex)
Rule of thumb
anything connected directly to the head or block needs a gasket
Old Oct 20, 2002 | 11:17 PM
Vanilla Ic3's Avatar
Default Re: should there be a gasket between manifold and turbo ? (The Shodan)
Welp.. that didn't really help since the turbo doesnt connect directly to the block.
You don't necessarily have to use a gasket, but if the mating surfaces are not completely flat, then you will have leakage. It's better to use one if possible.
Old May 13, 2003 | 03:44 PM
integra-modder's Avatar
Default Re: should there be a gasket between manifold and turbo ? (Vanilla Ic3)
can someone tell me which way you point the Garrett gasket? does the lip of the gasket, the part that is pushed out from the flat surface stick up toward the manifold or down against the turbo?
Old May 13, 2003 | 03:45 PM
Flamenco-T's Avatar
Default Re: should there be a gasket between manifold and turbo ? (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">can someone tell me which way you point the Garrett gasket? does the lip of the gasket, the part that is pushed out from the flat surface stick up toward the manifold or down against the turbo?</TD></TR></TABLE>
anyway will work.
stan
Old May 13, 2003 | 05:18 PM
Default Re: should there be a gasket between manifold and turbo ? (Flamenco-T)
thanks
b18-c-rx
May 18, 2005 07:10 AM
4-banging
Mar 15, 2004 12:03 PM
b18b1hmtlove
Feb 24, 2004 06:18 PM
1.8T_EG
Sep 12, 2003 07:00 PM
