filling tranny, small bb flowed out at the end, after tranny job
Old Jan 30, 2013 | 07:44 PM
dazebreak's Avatar
Icon2 filling tranny, small bb flowed out at the end, after tranny job
'95 Civic DX D15B7
So, the other week I replaced my tranny input shaft bearing. I was careful and followed a guide from the FAQ here. The bearing was definetly in need of replacement. I didn't inspect the rest too carefully, but what I saw and turned seemed ok. Put it back together with the Hondabond, let it cure, etc.
When I added the Honda Genuine MT fluid, at the very end when it was full, a small bb flowed out.
The car shifts and drives fine. I'm not going back in there soon, thank you very much.
I am curious, anyone have any idea which bearing it might be from? How worried would you be?
Just under 4mm diameter.
Old Jan 30, 2013 | 08:16 PM
Emeraldbomber's Avatar
Default Re: filling tranny, small bb flowed out at the end, after tranny job
Could have been one of the ***** inside the old isb that fell out and you didnt notice. That or one from the mainshaft bearing at the top of the shaft.
Old Jan 30, 2013 | 08:18 PM
Former User's Avatar
There's a bunch of steel ***** used in the transmission:
Old Jan 30, 2013 | 08:22 PM
Wow I didnt know they used that many. Thanks for the info Ron.
Old Jan 30, 2013 | 08:27 PM
JDMB1692EG's Avatar
Drive it till It breaks then fix it if you really don't want to redo it again now lol. You would believe how much a honda can take.
Old Jan 30, 2013 | 08:34 PM
dazebreak's Avatar
Yup, look at that, it was probably one of those. Thanks. (I think the ISB ***** are bigger too, but I threw it away before I refilled the fluid anyway)
Yeah...I don't know when I will have time to get back in there. Sooo, if it breaks I will fix it then, lol. Or maybe if I get done with all my other car projects first.
Old Jan 31, 2013 | 05:30 AM
94EG8's Avatar
Seagull Management
I've taken apart and rebuilt a bunch of these transmissions and I can't ever recall seeing a bearing that small.
Old Jan 31, 2013 | 07:13 AM
dazebreak's Avatar
Yup, then it is probably one of those steel *****, not a busted bearing. Still not good, but I feel a little better. It looks fun trying to find which one is missing.
Old Jan 31, 2013 | 11:03 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Question: How did the bb flow out when you were *filling* it? Don't you do this from the top of the tranny?
Old Jan 31, 2013 | 11:09 AM
94EG8's Avatar
Seagull Management
No I mean literally nothing in there is that small. All the detent ***** are about 5/16"/8mm I have no idea where that came from, but it wasn't supposed to be in there.
Old Jan 31, 2013 | 11:19 AM
dazebreak's Avatar
I use the proper fill hole with the car level on 4 jack-stands. When the fluid is full, it overflows a bit. That's when it came out. I didn't have a tube and funnel handy, so I used a pump attached to the MTF bottle with the plastic hose stuck in the fill hole. But yes I was above it looking down. I do realize a funnel with a tube would be easier, but it was easy enough.
Does that answer your question?
Old Jan 31, 2013 | 11:20 AM
dazebreak's Avatar
Ah, I see. That's good, I guess.
Old Jan 31, 2013 | 11:26 AM
I think the question concerns the conundrum that a dense steel ball would eject from the fill hole by floating on the top of MTF.
Old Jan 31, 2013 | 11:35 AM
dazebreak's Avatar
True, true. I guess it was just close enough to the opening and the flow was strong enough that it came out on the current. Or something. It doesn't weigh much anyway. I didn't put it in there or anything, I was careful to keep it on a clean garbage bag, and a clean tarp when I took it apart and put it back together for the ISB and oil seal for the ISB.
Well, I guess I won't worry about it.
Old Jan 31, 2013 | 05:18 PM
dazebreak's Avatar
I guess it somehow could have come from the new cheap fluid pump I was using, or one of the MTF bottles, anything is possible.
Old Feb 1, 2013 | 09:27 AM
sde780's Avatar
Most likely it was from your transmission, not the MTF you used
Did you keep track of the steel ***** underneath bolts (mentioned above) during the rebuild? I almost lost one when I rebuild my transmission, it's easy to forget one
Old Feb 1, 2013 | 11:19 PM
dazebreak's Avatar
It wasn't a rebuild, only an input shaft bearing and oil seal change. I didn't have to remove any steel *****.
94EG8 above said nothing in the tranny is that small.
It works, so I will drive it until it breaks.
Old Feb 3, 2013 | 10:07 PM
dazebreak's Avatar
OK, I investigated the pump I used, and guess what? This piece of **** was the cause, and it was the first time using it. It was some cheap tool from the parts store. Next time I will get some tubing from the hardware store big enough to go on the end of a funnel.
Here is a view looking at the bottom of the pump, there is another ball waiting inside. This is where the tube attaches to go into the bottle of fluid.
The package should say "steel ball insertion device for your vehicle."
Old Feb 4, 2013 | 06:06 AM
GRNcivEX's Avatar
Glad you got to the bottom of it. At least it fell out instead of floating around your tranny.
sanman000719
Transmission & Drivetrain
Feb 7, 2010 04:34 PM
Jimmy
Sep 9, 2004 06:25 PM
OKSolSi
Oct 6, 2002 01:36 PM
SoloSol
Jan 28, 2002 07:16 AM
