sugaring
Old Jan 30, 2013 | 05:47 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default sugaring
I am (somewhat futile) attempting to fabricate a throttle cable braket and need to weld gussets on it. the material is a thin SS sheet. i get sugaring and cavitation on the OPPOSITE side of the weld, the bead itself seems to be ok, no burn throughs.
what do i do to alleviate the crap building up?
Old Jan 30, 2013 | 05:53 PM
markk449's Avatar
Default Re: sugaring
pretty sure you need to have it surrounded by an inert gas.
Old Jan 30, 2013 | 06:05 PM
well yes, back purging is the way to prevent it, but how do you back purge a flat piece of metal?
Old Jan 30, 2013 | 06:12 PM
2fast4u831's Avatar
I'm really 2slow
I think it would be easier to get some angle metal stock or bend some 1/8" AL. But on with the backpurging. Make a jig using U channel metal with capped ends and place the over part getting welded. May I ask what engine this bracket is for?
Old Jan 30, 2013 | 06:14 PM
thanks for the advice. i am fabricating a bracket for the CBR ITBs mated to a D16, using the stock CRX throttle cable. i do not think i can use a angle stock, as the shape of the bracket prevents it. i have also thought about using thicker aluminium stock, but the bracket at its flattest is around 4" long and i fear it will flex regardless.
Old Jan 30, 2013 | 06:25 PM
2fast4u831's Avatar
I'm really 2slow
No problem. If you post a picture of the itb's we might be able to give you some ideas.
Old Jan 30, 2013 | 06:41 PM
i'll mock up the cable and the bodies tomorrow.
here are some photos of them without the cable
you can see the original bracket in the first photo, i am extending the length to accommodate the longer adjusting mechanism of the CRX cable.
Old Jan 30, 2013 | 07:01 PM
2fast4u831's Avatar
I'm really 2slow
Nice. Post a picture of where you are mounting the bracket if you can.
Old Jan 30, 2013 | 07:16 PM
same location as the old one. i'll show some photos tomorrow.
Old Jan 30, 2013 | 08:31 PM
all_motor_mike's Avatar
what about getting some solar flux..... ive never used it but i would say this is the ideal case to use it based on what ive read about it here and there on the web.
mike
Old Jan 30, 2013 | 08:33 PM
i'll look into it, thank you.
Old Jan 31, 2013 | 12:36 PM
markk449's Avatar
I have used a setup that looks like a sand blaster cabinet that you pumped argon into to flat odds and ends. It uses a ton of argon though so its really not cost effective if you're paying for it.
EDT.
Are you doing itb turbo?
Old Jan 31, 2013 | 06:22 PM
yes, it is a CBR 929RR bodies mated to a custom manifold with a GT28RS turbo.
here is a photo of the discarded bracket with the burn through and the iteration of the bracket with today's final copy which is made out of thicker steel (i'll gusset it still, i think)
Old Jan 31, 2013 | 06:44 PM
para pat's Avatar
Solarflux will prevent the sugaring. But if this is just a throttle cable bracket, grind the sugaring off and call it done.
Old Feb 1, 2013 | 09:17 AM
onefstek's Avatar
^^^^ I used solarflux in the past and works great.
Stefan
Old Feb 1, 2013 | 09:09 PM
Def's Avatar
Def
Back it up with a piece of copper.
Old Feb 1, 2013 | 09:12 PM
you know, that is a good idea, it'll drain the heat off.
Old Feb 2, 2013 | 08:37 AM
wantboost's Avatar
Who is Mr Robot?
The copper will help, but I would put it in one of those argon tents..
Old Feb 2, 2013 | 09:46 AM
Def's Avatar
Def
It also traps argon on the backside. It's not as good as a full backpurge, but it gets pretty close with almost no effort.
Old Feb 2, 2013 | 12:40 PM
weiRtech's Avatar
OG Fabricator
the copper is a good trick for welding other materials where you want to prevent the weld from rolling over an edge on a thick block as well. why not just make the bracket in steel and paint it?
aaron
Old Feb 2, 2013 | 12:49 PM
it is in steel, but it isn't thick enough to resist the flex. the direction has changed (again), with the charge plenum planned i think i'll incorporate the bracket into that instead.
Old Feb 8, 2013 | 01:23 AM
h2.4's Avatar
purge block. **** a tent. really?
Old Feb 8, 2013 | 01:27 AM
h2.4's Avatar
Honestly, control your current. You should be able to weld your material w/o melting the backside. If not use a purge block. done deal.
Old Feb 8, 2013 | 02:44 AM
Discosteak's Avatar
Use copper to bleed some heat off of the part or use an argon closet. If its just a throttle cable bracket grind off the sugaring, paint it, and call it a day.
Old Feb 8, 2013 | 06:03 AM
HellaFab's Avatar
use thicker material.
That throttle bracket is just going to bend with use.
