Too much oil
Old Jan 30, 2013 | 05:28 PM
mrcoolhead's Avatar
Default Too much oil
Hi,
I have a Honda Civic 1996 DX with 162,000 miles. This car has been good for years but now I am having some minor problems. I need help.
This car does not tell me how much oil is in the engine sometimes. After changing the dirty oil I put in 3.5 quartz. I let the car sit for a while and check how much oil is inside. The level stays at the first notch as if there is almost no oil inside. Thinking that there is not enough oil in the engine I add more. I have now put too much oil in the engine. After driving it around the level is reading over the maximum amount.
How bad is this? What should I do now?
Old Jan 30, 2013 | 05:42 PM
Former User's Avatar
Default Re: Too much oil
Drain the excess oil.
Do you replace the oil filter when you change the oil?
Have you ever removed the valve cover to inspect the valve train?
Old Feb 6, 2013 | 12:05 AM
98bwahhek's Avatar
remove it by loosening up the oil plug
Posted from Honda-tech.com App for Android
Old Feb 6, 2013 | 02:30 AM
grumblemarc's Avatar
The Grumpiest
Using the wrong dipstick?
Old Feb 6, 2013 | 02:51 AM
CO671's Avatar
An excessive amount of oil can blow seals(think of it as putting too much water in a balloon), i'd just drain it all out, measure and refill to be safe, if you're super **** and don't want to re-use it or measure just purchase more oil. Either way, drain and refill.
lieiti
Honda Civic (2006 - 2015)
Mar 25, 2019 03:44 PM
mrcoolhead
Jan 30, 2013 05:30 PM
garyc17
Dec 24, 2008 08:02 PM
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
mixxed
Jun 27, 2003 07:52 AM
