Hesitation and bucking issue
Old Jan 30, 2013 | 08:53 AM
Recklesszz's Avatar
Default Hesitation and bucking issue
Okay, I have a 93 civic and my problem is while I am driving my car decides to lose acceleration start bucking. This all happens when I am just driving normally. i need some kind of explanation why this is happening.
Old Jan 30, 2013 | 09:08 AM
VtecCivic93's Avatar
Default Re: Hesitation and bucking issue
Need more info..
Is there any check engine lights? Original engine? Any modifications?
Old Jan 30, 2013 | 09:51 AM
Recklesszz's Avatar
Originally Posted by VtecCivic93
Need more info..
sometimes when it starts acting up like lose of acceleration and bucking when i come to a stop sometimes the check engine light come on and off the engine is a ls vtec completely stock.
Old Jan 30, 2013 | 10:00 AM
RT_NEWYORK's Avatar
What is the cel code ? Sounds like an iac valve problem
Old Jan 30, 2013 | 11:33 AM
Recklesszz's Avatar
havent checked for the code but you think it iacv. what could be wrong with it ?
Old Jan 30, 2013 | 11:37 AM
Former User's Avatar
The IACV would only affect idle speed.
Pull the CEL code and do a tune up - plugs, wires, cap, rotor, ignition timing, fuel filter.
Old Jan 30, 2013 | 06:16 PM
RT_NEWYORK's Avatar
Only reason I suggested iacv was because mine just went on my em1 and I had alot of the same symptoms
Old Jan 30, 2013 | 08:30 PM
brettnahmann's Avatar
i drove thru a flood once and i got my ignition coil wet (inside the dizzy cap). when i would accelerate in 1st gear, it would bog down and hesitate until i let off the gas. if your bucking while accelerating, it could be an ignition component failure. open the dizzy cap and look for any wetness. p.s. the ignitor coil is only $70 and replacing it wouldnt be a bad idea eitherway. good luck!
jdmperspective
Aug 1, 2010 05:45 PM
Berge9798
May 27, 2008 10:10 AM
1998_4dr_gsr
Oct 27, 2006 03:21 PM
ThefirstPACT
22
Jan 11, 2004 07:17 AM
Fatty_1775
Jul 20, 2003 10:23 PM
