95 civic wiring and sensor issues
Old Jan 29, 2013 | 11:41 AM
Procomp95's Avatar
Default 95 civic wiring and sensor issues
Ive got a 95 civic with a zc motor i put in it i need help determining which wire is to the fuel pump i believe the wire into the connector is loose which is causing the fuel pump to shut off and on while driving if i play with the connectors next to the battery it turns it on so i was wonder if i could bypass the connector and just solder the wires for the fuel pump together. If i do this i also need to know what color the wires are for it i cant seem to find it in my manual anywhere so if anyone has what color wire goes to what that would be much appreciated.
the other problem i have is my vehicle wont stay at idle i am going back and forth if its the TPS sensor or the IAC sensor when i unplug the IAC it goes from pulsating to a faster pulse but if i pull off the connector to the TPS it stays at idle does anyone know any more specifics to what the problem might be i would rather spend the 35 bucks to get the TPS instead of spend 155 bucks for the IAC
Old Jan 29, 2013 | 12:22 PM
Procomp95's Avatar
Default Re: 95 civic wiring and sensor issues
The shocktower is where i am having an issue if that helps
Old Jan 29, 2013 | 01:06 PM
Former User's Avatar
Post pictures of the connector and wires you are wiggling. I don't think there are any fuel pump wires on the shock tower.
You should start by cleaning the IACV and FITV.
gorsey
Aug 8, 2011 01:26 PM
efhondaracer27
May 24, 2010 07:54 AM
99ssinoc
Jul 2, 2007 05:44 AM
q.man06
Feb 25, 2006 07:54 PM
c_buz
Feb 3, 2005 05:58 PM
