Clutch sticks to floor
Old Jan 21, 2013 | 12:30 PM
JoshV1288's Avatar
Default Clutch sticks to floor
I just replace my master cylinder to fix the clutch sticking to floor but it still sticks. Any suggestion? Slave cylinder possibly?
Old Jan 21, 2013 | 12:38 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Clutch sticks to floor
Check it.
Old Jan 21, 2013 | 01:08 PM
cvcrcr99's Avatar
Did you bleed the air out? Did you "bench bleed"? Are you still loosing fluid?
Old Jan 21, 2013 | 02:03 PM
JoshV1288's Avatar
Yes I bleed and re bleed but wat is bench bleeding
Old Jan 21, 2013 | 02:06 PM
CO671's Avatar
Tighten the nipple on the slave cylinder and refill + pump the fluid.
Old Jan 21, 2013 | 02:07 PM
dirty19's Avatar
Ridin Dirty in Cali
Google a vid for it. its not terribly hard and not always necessary.
Old Jan 21, 2013 | 02:18 PM
JoshV1288's Avatar
I released all fluid from the slave by loosening the nipple and pumping the clutch so all the fluid was out retightened it and filled reservoir and pumped the clutch until no air bubbles could be seen but the pedal never tightens up just sticks to floor
Old Jan 21, 2013 | 02:36 PM
CO671's Avatar
Its a very simple system actually. Be sure the lines arent leaking so look for signs of leaks as the fluid only goes one way. If theres no pressure with a new master it could be the slaves fault. Did you install the master correctly? Really, its not difficult.
Old Jan 21, 2013 | 02:50 PM
JoshV1288's Avatar
Yea it's pretty straight forward drain the reservoir remove the lines unbolt from pedal and firewall and ur done but I'm just gna replace the slave
Old Jan 21, 2013 | 06:01 PM
JoshV1288's Avatar
Ok just replaced the slave still have the same problem
Old Jan 21, 2013 | 06:41 PM
CO671's Avatar
Okay check the lines and master operating rod.
Old Jan 22, 2013 | 12:07 AM
crxbox360's Avatar
I have the same problem, it doesn't stick to the floor, but it's really soft. I've replaced both the master and the slave, bled the $h!t out of it, and still soft. I've replaced the clutch and replaced the bearings in the transmission too.
Old Jan 22, 2013 | 01:24 AM
eghatch9295's Avatar
Stancetard Hate Monger
you have a leak at a fitting or an improperly installed mc.
Old Jan 22, 2013 | 08:46 AM
24TEN's Avatar
PHANTOM MENACE
If this is exactly what you did, that doesn't sound entirely correct.
Old Jan 24, 2013 | 10:31 PM
JoshV1288's Avatar
ok Ill check all fittings tomorrow. I didnt see a leak in the line but will redo tighten all fittings tomorrow and rebleed
Old Jan 25, 2013 | 05:02 AM
The Grumpiest
I doesn't. All the fluid was out? You opened the bleeder and pumped until no more fluid was coming out of the bleeder? Wrong. All the in air the line was out. Better.
Old Jan 25, 2013 | 06:06 AM
24TEN's Avatar
PHANTOM MENACE
Thank you sir, for a while I thought I was going crazy since no one seemed to say anything about it.
Old Jan 25, 2013 | 05:42 PM
JoshV1288's Avatar
ok i bleed it right now so it stiff but it doesnt come back into position
Old Jan 25, 2013 | 07:35 PM
dazebreak's Avatar
Yeah, adjust clutch pedal height also.
Old Jan 26, 2013 | 02:41 AM
The Grumpiest
Explain EXACTLY how you did that. Because what you thought you were doing before was right.
pair8hd
16
Mar 11, 2020 06:40 PM
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
autoxthis
Aug 21, 2008 08:23 PM
dem0nk1d
Oct 26, 2006 12:01 PM
