Pintle cap cracking off, causing catastrophic failure?
Alright I bought this car with this motor, got a good deal on it yada yada.
It has blue top DSM injectors, 450cc. Cylinder 1 has half a pintle cap. Like so.
This is the same cylinder that has a broken valve that looks like so.
This motor was obviously driven for a while with this problem. Oil is everywhere and the turbo is, well, f**ked. Ebay turbo, not worried about that loss.
Anyways, I'm just wondering if that cracked pintle cap could have caused that failure. If so, should I remove all the pintle caps if I plan on using these injectors?
Yeah, but, is this a common problem with dsm injectors? If it is, I can't think buying a new set will help if the pintle caps just break off again.
D16SohcVtec
Jul 17, 2006 06:00 PM
eastbay92cx
Nov 26, 2004 07:40 PM
