dsm blue tip injector :(
Old May 22, 2004 | 11:26 AM
Tex Blackwell's Avatar
Default dsm blue tip injector :(
think i can run the injectors without the cap and just them sticking inside the manifold? A couple of my caps on the actual injectors are cracked and i cant find any of the little caps that go on the tip. Rockingham is tomorow but if i can run the injectors without the caps then i guess i'm fine without them.
Old May 22, 2004 | 11:53 AM
DaX's Avatar
DaX
Loved
Community Favorite
The caps just protect the pintles. You don't "need" them.
Old May 22, 2004 | 08:26 PM
Infinity_Racer's Avatar
Default Re: (DaX)
yeah i ran my civic without those caps for about 2 months...it worked fine and everyone on ht told me it was ok to run it like that...
Old May 22, 2004 | 10:49 PM
blackeg's Avatar
Default Re: (Infinity_Racer)
wow, 2 of my 4 dsm 450's dont have those little black caps that go on the end of the injector. i called the local mitsubishi dealership and the parts guy said that if its not o-rings, then they probably dont sell them individually from the injector. so its okay to run the injectors w/o those caps then???
Old May 22, 2004 | 10:53 PM
SOHC_MShue's Avatar
Default Re: (blackeg)
yes its ok. I run one of my 450's without the cap. If the cap is cracked though I would just go ahead and remove the whole thing so the little pieces don't fall into your intake manifold.
Old May 23, 2004 | 08:57 AM
blackeg's Avatar
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yes its ok. I run one of my 450's without the cap. If the cap is cracked though I would just go ahead and remove the whole thing so the little pieces don't fall into your intake manifold.</TD></TR></TABLE>
ok awesome. this just made my life much easier
Old May 31, 2004 | 10:37 PM
ran perfect, 13.2 @ 111mph
bad thing is, at the track it rained for about 2 hours before, so i never got a chance to lower the tire pressure or actually run on a DRY TRACK!
only got to run 1 time.
eastbay92cx
Nov 26, 2004 07:40 PM
ITSTOCK
Feb 4, 2004 05:36 PM
racerxadam
Mar 26, 2002 08:32 PM
