Help with clutch/transmission problem !
Old Jan 14, 2013 | 08:36 PM
Edwaad Truon's Avatar
Default Help with clutch/transmission problem !
Hey guys, my car is a 2000 Honda Civic EX. When I clutch in to shift from 1st to 2nd gear I feel something shake and also hear a spinning sound. 1st to 2nd gets notchy and sometimes my gear grinds. Finally, when I am in first gear cruising in for example, a parking lot every time I gas a little bit the car jerks foward. Any ideas on what these problem this might be? Any help would be appreciated.
Old Jan 14, 2013 | 08:54 PM
Former User's Avatar
Default Re: Help with clutch/transmission problem !
Only when pressing the clutch pedal down or when trying to shift with the clutch pedal down? Do you feel the shake in the gear shifter or clutch pedal?
Old Jan 14, 2013 | 11:36 PM
It happens right when I clutch in to shift to 2nd gear. So right when I press on the clutch pedal to shift to second I feel a sudden jerk and hear a spinning noise. The shifter moves violently.
Old Jan 15, 2013 | 10:24 AM
You probably have several different issues:
-The rear engine mount may be loose or bad, but check all the mounts.
-The clutch throw out bearing may be bad and causing the noise.
-You may reduce the shifting problem by replacing the transmission fluid with fresh Honda MTF.
ThaEfSwap
Nov 29, 2011 06:37 PM
taimysho0
Sep 24, 2007 05:15 PM
jli18
Nov 5, 2006 09:12 PM
Chief Brody
Aug 4, 2004 09:28 PM
Kevins2k
Jun 11, 2003 10:56 PM
