93 Del Sol roof still leaking after new seals
Old Jan 11, 2013 | 09:40 AM
k.gren's Avatar
Icon2 93 Del Sol roof still leaking after new seals
So i'm at a loss and don't know what to do anymore. Bought my Sol last year for cheap as a project car and for gas mileage since my truck gets horrible gas mileage. After buying it I noticed two bad leaks on each side where the triangle glass meets the pillar/roof. Everything I read was to get all new weatherstripping to fix the problem. Gritted my teeth, bought it and had it professionally installed. Still leaks. What can I do?
Old Jan 11, 2013 | 09:45 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: 93 Del Sol roof still leaking after new seals
Has the car been in an accident? I hear this can cause them not to seal.
Old Jan 11, 2013 | 11:19 AM
250r king's Avatar
This is how I fixed mine roll the window down . Pull the triangler piece inward and it will stop the leaking . Also check the target top latching points they maybe worn out not putting enough bind on it.
Old Jan 11, 2013 | 12:51 PM
london ritzler's Avatar
i have the same leak in those spots, still can't fix it.
Old Jan 11, 2013 | 03:33 PM
Burningrambo's Avatar
The door lining up correctly? Fixed mine for the most part.
Old Jan 11, 2013 | 04:54 PM
gzes's Avatar
Do you ever take off the top? If not then you can probably foam it but remember that ot will stop the leak and you wont be able to take the top off
Old Jan 11, 2013 | 05:02 PM
Lizardslap's Avatar
put some washers under the roof latch part on the body side and they will sit a bit lower and force the seal tighter works for me and I have a fairly badly damaged seal stays dry except when it really really pours
takes a bit of trim removal and unbolting and what not but you only need to do it once
Old Jan 12, 2013 | 01:28 AM
ferio-lover's Avatar
check out this rubber sink i show on picture ,mine sol was cut both and leaks both in point between seat and door.
Old Jan 12, 2013 | 05:57 AM
Lizardslap's Avatar
small pic what exactly am I looking at I see the red line but whats different
Old Jan 12, 2013 | 06:16 AM
HondaPartsHero's Avatar
Technical Hero
Not sure if this will help
http://www.ozhonda.com/forum/showthr...leakage-fix-up
http://www.ozhonda.com/forum/showthr...k-ultimate-fix
Old Jan 12, 2013 | 07:18 AM
k.gren's Avatar
I'm not fully understanding what you mean by this?!
Old Jan 13, 2013 | 06:29 PM
k.gren's Avatar
Well, I pulled on the triangle glass to move it in to create a better seal. It helped out a lot. Barely any leaking now. I think this coming weekend when I have time I am going to adjust my doors up and hopefully that completely fixes the problem. Thank you all for your insight!
Old May 2, 2013 | 12:27 PM
RitaCG's Avatar
Hi all,
I got new Weatherstrips from Majestic for both sides of the roof and my shop guy installed them for me. I watched him while he was doing it and saw that there was an adhesive strip on them and that the install was fairly easy when you have the right tools. I now bought the large front pillar weatherstrip that goes from door to door and am wondering if I can install that myself, and if there is an adhesive strip on that seal too or if I need some additional sealant or glue and if so what type and where to get it.
Thanks for your feedback.
Rita
Spooled91
Oct 30, 2009 05:50 PM
hnp5
Sep 15, 2005 02:01 PM
crucial_delsol
Apr 6, 2005 09:29 PM
DC*whore
Oct 21, 2004 09:41 AM
Hondizzle!
Jun 9, 2003 05:14 PM
