D16 piston available with 21mm pin?
Old Oct 20, 2002 | 11:44 AM
earl's Avatar
Default D16 piston available with 21mm pin?
I am rebuilding a D16Z6 motor that was previously built with 21mm pins fitted to stock LS rods. It will be boosted to about 10 lbs. Do I need to have a custom set of pistons made (D's are normally 19mm pin diameter) or is there a shelf piston that will work with this combination? Do you guys think it is better to bush the ls rod to 19mm or hone an aftermarket piston to the 21mm pin size?
Old Oct 20, 2002 | 01:34 PM
Replica_Racer's Avatar
Default Re: D16 piston available with 21mm pin? (earl)
Bumb
Old Oct 20, 2002 | 01:48 PM
Sonny's Avatar
When I talked to JE and Endyn, they would basically make whatever you wanted custom, but you would have to buy 2 sets.
I would think that a good machinist would have no problems in opening the wrist pin holes on the pistons to accept a 21mm pin and then recutting the circlip groove. It sounds like it could get expensive though and I don't know if doing this to any of the pistons designed for 19mm pins will effect their strength.
I don't think the bushings are as precise, but they are certainly a lot more cost effective.
Sonny
LS/V-T
Jan 5, 2011 09:19 AM
EKSedAndy
Apr 22, 2010 06:05 PM
Flexin5
Nov 9, 2005 05:08 PM
gaskleppie
Apr 14, 2004 09:34 AM
alfee
Mar 28, 2004 10:08 PM
