99 civic ex shakes
it started as a small problem it started shaking real bad only while i was driving and its gotten worse it shakes when in drive while driving if u put it in neutral while ur driving the shaking stops i already changed all motor mounts and tie rod ends any input would be greatful im lost on what to do it shakes to the point where u cant drive it my dash is flexing uo to 3 inches while its doing this also as i decelerate u can feel a thumping in the floor board u can also hear it
If you driving and rolling in neutral and the shaking stops and If the shaking returns when in gear, then sounds to me like an axle(s) going out..
Make sure motor mounts are also in good shape. After a while a mis-aligned transmission will eat up an axle.
You can also check to see if your steering rack (tie rods) and bearings are still good ? Put it in the air and grab the wheel, 12 / 6 o'clock to test for bearing and 9 / 3 o'clock for tie rods.
