integra problem
Old Sep 10, 2012 | 09:14 PM
kodylive's Avatar
Default integra problem
when im driving i can hear a lould clunking and can feel it and its bad makes the whole car shake it does it alot when truning and does it when going stright less but still bad what could it be im thinking its the cv axel but is there anything els it could cause this?
Old Sep 11, 2012 | 12:53 AM
B20ztek's Avatar
Default Re: integra problem
Tires/bent wheel, or motor mounts. Thats about all it could be other than the axle.
Old Sep 11, 2012 | 03:16 AM
Dogginator's Avatar
Daisy... Daisy...
I'd throw brakes on that list too. How fast do you have to drive for this clunking to occur? If it is low speed, have someone stand outside of the car and listen to better locate the source.
Old Sep 11, 2012 | 04:52 AM
mayfly's Avatar
axles. i had the same problem. i was on a road trip and started having terrible shaking, i knew the axles were going bad before though, but after changing them it was fixed. look to see if you have a torn boot, no grease after a long time will do that
Old Sep 11, 2012 | 04:08 PM
dc2LS's Avatar
It sounds like your axles.Does the sound get louder when you take sharp turns?
Old Sep 11, 2012 | 09:46 PM
kodylive's Avatar
yep it does and you can feel the whole car shakeing when it happens
Old Sep 12, 2012 | 04:14 PM
kodylive's Avatar
rims are not bent and all the mounts are good so must be the axel
Old Sep 22, 2012 | 11:46 PM
kodylive's Avatar
found the problem it was the trans took it out and looked at it today final drive gear is bad all the bearinging are bad and the case is craked yust my luck!
Old Sep 23, 2012 | 05:29 AM
Dogginator's Avatar
Daisy... Daisy...
That's not good, but at least that is easy to swap. How many miles were on it?
Old Sep 24, 2012 | 09:33 PM
kodylive's Avatar
only 132000 and it was kept up good
Old Sep 30, 2012 | 03:43 PM
kodylive's Avatar
Yust got my new gsr trans in and its pulling harder then ever
Posted from Honda-tech.com App for Android
bentbobb
Aug 14, 2012 11:28 AM
BoltonGSR
Apr 3, 2009 06:15 AM
rattlecanjoe
Feb 16, 2007 12:48 PM
servion
Jul 7, 2003 07:06 AM
MisterB
May 9, 2002 03:54 AM
