how do you will make this?
want to make a flange for TD04 with the same turbine specs than this:
http://www.ebay.com/itm/CXRacing-GT1...-/140744553765
any help will be appreciate it a lot!
Thanks
Thanks
not sure how this can be done without a proper tubing expander, or cutting a flat piece of steel and rolling it, but you will save yourself a whole lot of headache by just buying one
http://www.verociousmotorsports.com/...nd-Transitions
i see, it's ok, i will try to paid for a tool that can be make these with press ..
ok, i have a question about that flange since i will make a downpipe, it's possible that turbo use the same turbine as GT2052 ? it looks the same but idk know about sizes!
BS we have a giant flare forming tool that we make cones just like that with in a 20 ton hydraulic press.
The thing is you must find the proper angle to use and use the proper thickness material.
No I'm not giving away the info, just saying that it can be done quite easily with a little trial and error
Who is Mr Robot?
I was saying you can't do it, not simply
It would take trial and error on material, mandrel size, angle, etc,
So much easier to just buy one
KENetics1
Welding / Fabrication
14
Mar 3, 2008 12:45 PM
