94 eg hatch si spark plugs wire help
Old Jan 7, 2013 | 01:49 PM
Hyunbs's Avatar
Default 94 eg hatch si spark plugs wire help
Hi i was trying to replace my sparkplugs in my car 94 civic si hatchback running a mini me swap. The one probalem i have is this. The spark plugs wires wont come out of the head... All of em are on there really well. Cant pull em off. And i was trying to pull em off forcefully and this happened. Any way that they are stuck? Dont know what happened... Bought the car like this. Help please!! Any help/ advise is helpful!!
Old Jan 7, 2013 | 02:06 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 94 eg hatch si spark plugs wire help
By any means necessary. Try pulling off the valve cover?
Old Jan 7, 2013 | 05:44 PM
chinochanginc's Avatar
That won't help, the spark plug tubes touch the top of the valve cover. You won't have access to the sides of the cable. Try spraying some wd40 down the center of the spark plug cable tube with a straw). Then get a pair of needle vice grips to twist and loosen the plastic rubber
Old Jan 7, 2013 | 05:54 PM
The Grumpiest
It was just a suggestion since I've never had to deal with a problem like this. The thought was that even with the boots stuck in the tube you could pull the V/C and get at it from the other side. There's going to be no easy way of doing this. Last time I read of a problem like this the car was overheated to the point that the boots melted to the inside of the valve cover. If that's the case WD-40 is doubtful to work but at this point give it a shot. It's also worthy to mention that the head was warped pretty badly because of the overheating.
Old Jan 7, 2013 | 07:00 PM
98civdx's Avatar
Master Detailer
Small flat blade screw drive. Stick it in and work it around in a circle. grab some vice grips and jiggle, twist whatever on the end.
Old Jan 7, 2013 | 10:17 PM
Psychoteen101's Avatar
Needle nose pliers or vise grips. Twist in a circular motion before you try removing the boot. Dont pinch the boot too tightly because it will just rip farther down. Just enough to get it to turn
Old Jan 8, 2013 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
That's pretty typical of a neglected and/or over heated head. Try and like above with some penatrant and pull that plastic portion off with some long needle nose pliers. More than likely the boot that goes around the plug will remain. Use a long flat tip screwdriver and/or a coat hanger to remove it. Keep at it, good luck.
Old Apr 22, 2013 | 11:49 PM
Hyunbs's Avatar
Thanks guy, i forgot to post. I got em out with some vise grip pliers. They were just stuck on there really well
Old Apr 22, 2013 | 11:50 PM
Hyunbs's Avatar
Guys*
drew_kousk
Oct 5, 2010 01:32 AM
AcuraIntegra_19_94
Jan 22, 2009 06:14 PM
joe.wong321
20
Mar 5, 2008 07:21 PM
mega502
Aug 6, 2007 09:32 AM
timmya
12
May 6, 2006 08:18 AM
