Engine Options
So after doing alot of research and reading up I am trying to figure out which route to go for my base engine. I currently have a 2000 Ls with the base b18b, but cant decide if I want to do a LsVtech with a b16 head, or just swap it completely with a b18c gsr or type r. My goal is 350-400 hp and I will be going the FI route with a turbo soon after the swap is complete. Any feedback to help me make my decision would be appreciated.
I got a boosted ls in a 93 hatch on 10psi. I got 300whp on stock internals. Now I be took apart the block and replaced with
eagle rods,
arp rod bolts,
9.1 cp pistons with rings
Cometic headgasket
Tuned with hondata s300
Stock head cylinder
With rc 1000cc injectors
Still in the process of pushin up the boost to mayb 12 or 13psi
But got a problem with idling up and down on cold start but idles normal when its warmed up. Confused?
I've changed out iacv and cleaned fitz. And sprayed the vacuum hoses and gasket with carb cleaner still nothin
eagle rods,
arp rod bolts,
Cometic headgasket
Stock head cylinder
Oh forgot I also got
.70 trim Garrett turbo
With gsr tranny
Clutchmaster flywheel
Competition act 4puck sprung clutch
Boost it man you'll gain lots of power even on stock internal with 10psi.
With gsr tranny
I assumed this wouldn't be done without a properly built block. I forget people cut corners. But you are on point.
By now the engine probably has enough miles on it that even a low-boost build would be a bad idea without rebuilding the engine. Why invite trouble. Even 250 whp is 170 flywheel hp per liter...
kidcivic90'si
Jan 16, 2013 08:41 AM
skillzhb
Jan 10, 2009 10:40 PM
streetracerof06
18
Jun 5, 2006 01:09 PM
