b16 block
Old Oct 17, 2007 | 09:57 AM
soon2bdropped's Avatar
Default b16 block
can you do a b16 bock with an ls head will it still run or run like ****...
same as gsr block with ls head...
Old Oct 17, 2007 | 10:24 AM
dizzzane's Avatar
Default Re: b16 block (soon2bdropped)
They are both going to run like *** unless you tune it?
Old Oct 17, 2007 | 11:22 AM
gibsanez's Avatar
Why would you want to do that? Either way, you putting a non-vtec head on a smaller block than they came on.
Old Oct 17, 2007 | 08:41 PM
Default Re: b16 block (gibsanez)
would that mess around with compression ratio at all.. why is it not a common swap.. and whats the cons on it thanks
Old Oct 17, 2007 | 10:15 PM
davidluko's Avatar
Yes it'll "mess around with" the compression, the LS head has a larger combustion chamber and will lower compression (which means less power). It's not a common swap because that's the worst of both worlds, it's like taking the leftover scraps from someone else's project. You mate the smaller-displacement block with the worse-flowing head for less power than a stock LS or stock B16 engine... what's the point? Not only that, but then you'll dump money into tuning it - ending up with an engine that is more expensive and causes more headaches than a stock engine, but makes less power.
Old Oct 18, 2007 | 08:19 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">can you do a b16 bock with an ls head will it still run or run like ****...
same as gsr block with ls head...</TD></TR></TABLE>
what exactly is the logic here?
eastbayg
Sep 10, 2009 08:42 PM
smashdippn
Nov 14, 2008 11:31 PM
JspecCivic94
Oct 25, 2005 06:26 AM
wade
Jul 1, 2004 08:53 PM
Kanscrx
Jun 25, 2004 11:11 AM
