Engine Options
Old Jan 3, 2013 | 08:18 AM
ArmyTeg's Avatar
Default Engine Options
So after doing alot of research and reading up I am trying to figure out which route to go for my base engine. I currently have a 2000 Ls with the base b18b, but cant decide if I want to do a LsVtech with a b16 head, or just swap it completely with a b18c gsr or type r. My goal is 350-400 hp and I will be going the FI route with a turbo soon after the swap is complete. Any feedback to help me make my decision would be appreciated.
Old Jan 3, 2013 | 08:45 AM
pimpwagon's Avatar
Default Re: Engine Options
Any one of those can make the number you want. I'd do it by what you can do the cheapest, but using the most new parts.
Old Jan 3, 2013 | 10:24 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Like above you can achieve the power on all b series engines, but it's recommended to use some after market internals
Old Jan 3, 2013 | 10:29 AM
ArmyTeg's Avatar
Im sure the b16 lsvtech would be the cheapest.
Old Jan 3, 2013 | 10:38 AM
ArmyTeg's Avatar
Also would it be better to build the head from scratch and rebuild the block or to build the head from scratch and rebuild the block?
Old Jan 3, 2013 | 10:52 AM
doood's Avatar
been there done that
what's wrong with the current engine? boost that.
Old Jan 3, 2013 | 11:09 AM
ArmyTeg's Avatar
One of the main reasons for doing it is to get that extra kick on high rpms when I am stretching it out on the highway
Old Jan 3, 2013 | 07:57 PM
dc2LS's Avatar
Why dont you build your b18b if your gonna be pushing those numbers your gonna have to build the internals to handle that much boost.I say build your b18b.
Old Jan 3, 2013 | 08:02 PM
GagnarTheUnruly's Avatar
Just boost what you've got.
Old Jan 4, 2013 | 03:41 AM
ArmyTeg's Avatar
What kind of work would be needed to get my Ls to 350 hp?
Old Jan 4, 2013 | 06:23 AM
Eg.ls.turbo's Avatar
I got a boosted ls in a 93 hatch on 10psi. I got 300whp on stock internals. Now I be took apart the block and replaced with
eagle rods,
arp rod bolts,
9.1 cp pistons with rings
Cometic headgasket
Tuned with hondata s300
Stock head cylinder
With rc 1000cc injectors
Still in the process of pushin up the boost to mayb 12 or 13psi
But got a problem with idling up and down on cold start but idles normal when its warmed up. Confused? I've changed out iacv and cleaned fitz. And sprayed the vacuum hoses and gasket with carb cleaner still nothin
Old Jan 4, 2013 | 06:29 AM
Oh forgot I also got
.70 trim Garrett turbo
With gsr tranny
Clutchmaster flywheel
Competition act 4puck sprung clutch
Boost it man you'll gain lots of power even on stock internal with 10psi.
Old Jan 4, 2013 | 12:02 PM
pimpwagon's Avatar
Possibly. You never know what is out there though. Sometimes you start looking and stuff just falls in your lap. Like my 94 LS. lol Best 1500 bux I never wanted to spend.
Old Jan 4, 2013 | 05:36 PM
Just boost the stock ls motor and get a gsr tranny. with that setup you'll b spinning 2nd gear like its first gear.
Old Jan 4, 2013 | 05:39 PM
Make sure u find a someone that knows how to tune a turbo setup engine good.
Old Jan 4, 2013 | 09:25 PM
dc2LS's Avatar
The most I would go an a stock b18b without building the internals is 250-285 hp ish if you want to push numbers higher than that I would build the bottom end.
Old Jan 8, 2013 | 09:19 AM
pimpwagon's Avatar
I assumed this wouldn't be done without a properly built block. I forget people cut corners. But you are on point.
Old Jan 8, 2013 | 09:24 AM
By now the engine probably has enough miles on it that even a low-boost build would be a bad idea without rebuilding the engine. Why invite trouble. Even 250 whp is 170 flywheel hp per liter...
Old Jan 8, 2013 | 09:42 AM
jazzRS's Avatar
sleeve and boost a b20 block on your ls head, use a gsr trans and 300whp will be a monster
kidcivic90'si
Jan 16, 2013 08:41 AM
skillzhb
Jan 10, 2009 10:40 PM
soon2bdropped
Oct 18, 2007 08:19 AM
streetracerof06
18
Jun 5, 2006 01:09 PM
