Rebuilt GSR Shortblock | Rebuilt High Compression LS Block | Fidanza Flywheel
Old Dec 29, 2012 | 09:37 AM
ryguy2588's Avatar
Default Rebuilt GSR Shortblock | Rebuilt High Compression LS Block | Fidanza Flywheel
The high compression LS block is freshly built and was ran for no more than 20 miles. I took the head off to replace the valve springs. This block will be very good for any LS/VTEC or LS build. I have the LS/VTEC conversion kit for it if you are interested in that as well. Here's what it has
Machine Work:
Hot Tank
Hone
Polishing Crank
Recondition Rods
Recondition Pistons
Hone Rods
Install Pistons on Rods
Block:
LS Rods
LS Block
ARP Rod Bolts
P30 Pistons
LS Crank
GSR Water Pump
NEW GSR Oil Pump
GSR Timing Belt
OEM Rear Main Seal
NPR Piston Rings
King Rod Bearings
King Main Bearings
King Thrust Washers
Gasket Kit
LS/VTEC Kit:
Golden Eagle Dowel Pins
Oil Sandwich Plate
Oil Fittings
Oil Line
Block: $600 + shipping with the LS/VTEC kit
I'm selling a freshly rebuilt GSR block. Completely stock. ZERO miles. Here's what it comes with and what has been done.
Machine Work:
- Hot Tank Block
- Hone Cylinders
- Polished Crank
Block:
- GSR Block
- P72 Pistons and Rods
- GSR Crank
- GSR Water Pump
- GSR Oil Pump
- OEM Rear Main Seal
- NPR Piston Rings
- King rod/main/thrust bearings
- Water Pipe
- Thermostat/Housing
The only thing it needs is one driver side mount bolt helicoiled.
GSR Block: $450 + shipping
Text me with any questions you have at 719-238-6833.
The only things I would be interested in trading for would be a Garrett or Turbonetics 50 trim turbo, a Tial 44mm wastegate, or a Tial Q blow off valve as of now.
Old Dec 29, 2012 | 09:46 AM
mouab18c1's Avatar
Default Re: Rebuilt GSR Shortblock | Rebuilt High Compression LS Block | Fidanza Flywheel
Are those rust spots on the ls block?
Old Dec 29, 2012 | 10:06 AM
ryguy2588's Avatar
I don't believe so...can an aluminum block rust?
Old Dec 29, 2012 | 10:08 AM
ryguy2588's Avatar
I'm not exactly sure what those marks are from other than dirty coolant just sitting in it for a while?
Old Dec 29, 2012 | 06:57 PM
ryguy2588's Avatar
ttt
Old Dec 31, 2012 | 10:28 AM
ryguy2588's Avatar
ttt
Old Jan 1, 2013 | 06:45 PM
ryguy2588's Avatar
ttt
Old Jan 3, 2013 | 08:59 PM
jdmem205's Avatar
Sorry for the noob question but whats helicoiled?
Old Jan 3, 2013 | 10:34 PM
ryguy2588's Avatar
It's where a machine shop, or yourself, installs new threads into a threaded hole of a material when the old threads have been stripped or damaged. You can also do what's called a time-sert. A helicoil has worked fine in every case I've needed one and doesn't cost more than $20 at a machine shop.
Old Jan 8, 2013 | 12:31 PM
ryguy2588's Avatar
ttt
Old Jan 8, 2013 | 01:55 PM
SobrietyRulesNA's Avatar
BUMP
Old Jan 8, 2013 | 08:10 PM
TTT..Damn if i wasnt building my own engine already i would jump on either one of these. Decent prices. GLWS!
typeRSXS
Mar 24, 2004 03:54 PM
tnsxsear1
Feb 8, 2004 03:33 PM
