came across a couple problems while tunning
Old Oct 19, 2002 | 08:55 PM
lsvtec94's Avatar
Default came across a couple problems while tunning
well i took my car to tome payn to get tuned today and after a couple pulls we ran into a slight problem...
[Modified by lsvtec94, 5:56 AM 10/20/2002]
Old Oct 19, 2002 | 09:50 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: came across a couple problems while tunning (lsvtec94)
and the problem was???????
Old Oct 19, 2002 | 09:58 PM
lsvtec94's Avatar
Default Re: came across a couple problems while tunning (Mista Bone)
sorry i was gonna post pic but they wont lod, i will try agan later
Old Oct 19, 2002 | 10:27 PM
Veil_Side_'s Avatar
can't help you if you don't tell us the problem cat
Old Oct 19, 2002 | 11:15 PM
LOtownNateB's Avatar
Default Re: came across a couple problems while tunning (Veil_Side_)
he was running prototype cams .... they had to much lift and were hitting the valve guides. the company is called LSM Motorsports, they are located in waterford ,MI. They said they would work with no problems and they didn't ... caused him to drop a valve ruining his motor that had 1000 miles on. SO PEOPLE BEWARE OF THIS COMPANY BECAUSE THEY DO NOT KNOW WHAT THEY ARE DOING!!!! DO NOT RUN THESE CAMS, THEY WILL $%@* UP YOUR MOTOR!!!! switched to Jun 3's but to late had slightly bent valves do to retainers hitting valve guides From LSM cams(loosing compresion and not letting valves move like they should). But still made 190HP at 8900 on 4th pull on dyno. Didn't even get to tune for power yet ... we were getting the air/fuel ready to right. Timning was set to around stock. everything was pretty much like stock nothing advanced or retarded. Anyone got any feedback on supertech valves? that is what valves he was running!!! i think it could have been cabable of 220-235 to the wheels, if it wasn't for the cams he had in ifroma LSM!!!!
Old Oct 20, 2002 | 12:33 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: came across a couple problems while tunning (LOtownNateB)
So he installed cams without checking clearances, another parts slapper bites a big one.
Anyone remember Crower issues with Jun valvetrain?
Learn to check motor/valvetrain clearances BEFORE firing motor.
Slapping parts is easy, know how to tune them is the key to divineness.
Old Oct 20, 2002 | 12:19 PM
LSM are the ones who checked for clearance issues and said there were none .... and this is supposed to be a shop who makes alot of **** for IRL cars
Old Oct 20, 2002 | 12:22 PM
94gsr's Avatar
Clay is a wonderful thing. **** taking someone else's word for it...
Old Oct 20, 2002 | 12:58 PM
Default Re: came across a couple problems while tunning (94gsr)
well we know that now .... they said they did all that stuff!!! only reason valve hit pistons is from the retainer smashing the top of the valve guides
Old Oct 20, 2002 | 05:48 PM
3rdGteg's Avatar
So the shop is not taking any blame for this or what?
Old Oct 20, 2002 | 09:55 PM
Default Re: came across a couple problems while tunning (3rdGteg)
haven't had a chance to talk to them yet .... we will soon though
Old Oct 21, 2002 | 07:55 AM
DonF's Avatar
The retainers hitting the guides would not cause the valve to hit the piston, as that would happen at over 100 degrees before or after TDC,depending on in. or ex. The valves would only hit the pistons during overlap and at less than .200 lift. Did the retainers come with the cams? Did they check the clearance on his head?
Old Oct 21, 2002 | 06:03 PM
Default Re: came across a couple problems while tunning (DonF)
yes it could cause the valves to hit pistons. for example .... what happens to the end of a punch after you hit it with a hammer for a period of time .... it mushrooms!! same thing happens to the valve guide. and that don't let the valve move as freely as it needs to
Old Oct 21, 2002 | 09:04 PM
ImportRacing's Avatar
did you change the springs along with the cams also or just the cams alone?
Old Oct 22, 2002 | 03:18 AM
Default Re: came across a couple problems while tunning (ImportRacing)
we changed springs too ... made by the same company as the cams
Old Oct 22, 2002 | 05:40 AM
sleepercivic's Avatar
yeah i heard about that, that really blows, heard your car was sitting out side of Motown muscle.
TERRY
Old Oct 22, 2002 | 04:59 PM
Default Re: came across a couple problems while tunning (sleepercivic)
yes it was .... where you from terry?
evildc2
May 13, 2009 07:56 AM
99em1_sir
Jan 4, 2007 10:21 PM
OvErReV121
Jun 13, 2005 05:16 PM
legendboy
Mar 11, 2004 08:59 PM
BreakStuff
Nov 29, 2001 06:54 PM
