B18b1 swap into eg - No MAF (Mass Air Flow) Sensor
Old Dec 27, 2012 | 02:15 AM
MTarry's Avatar
Default B18b1 swap into eg - No MAF (Mass Air Flow) Sensor
Hey, HT i had swapped my b18b1 OBD1 into my eg hatch and everything runs but i have a check engine light due to the fact that i have no MAF (Mass Air Flow) Sensor cause it had been cut off by previous own (Who knows what reason for that). But i have no luck with finding any 94-01 integras to pull one off of. So my question is. Would a MAF off of a integra 90-93 work?
Old Dec 27, 2012 | 02:26 AM
jbpnoman's Avatar
Default Re: B18b1 electrical
Except our cars use MAPs, not MAFs.
Old Dec 27, 2012 | 02:47 AM
MTarry's Avatar
Oh, sorry i wasnt sure i heard both from different people. Do you know if a DA integra MAP sensor will work if wired onto my OBD1 harness?
Old Dec 27, 2012 | 05:20 AM
dirty19's Avatar
Ridin Dirty in Cali
The map sensor is on top of the throttle body.
Does your engine harness have cut wires where one should of been?
If so.. yea wire one back in with the connector. be sure to do it properly(shrink wrap etc) and get one for a car that is odb1.
Old Dec 27, 2012 | 07:25 AM
Former User's Avatar
Default Re: B18b1 swap into eg - No MAF (Mass Air Flow) Sensor
Post the CEL code.
Old Dec 28, 2012 | 10:54 AM
MTarry's Avatar
Yes exactly. Im trying to do that but im having a hard time finding an obd1 but easy to find obd0
Old Dec 28, 2012 | 11:40 AM
dirty19's Avatar
Ridin Dirty in Cali
No wrecking yards where you are at?
Old Dec 28, 2012 | 11:46 AM
MTarry's Avatar
Yea there is. But its all obd0 integra's thats why i asked if obd0 would work on my harness?
Old Dec 28, 2012 | 01:09 PM
egsleepercivic's Avatar
you can use one off a civic thats obd1, not sure about the obd0 sensor though
Old Dec 28, 2012 | 01:15 PM
MTarry's Avatar
You sure? I still have the harness from my D15b8
Old Dec 28, 2012 | 01:19 PM
is the one on the d15b8 firewall mounted or throttle body mounted ?
Old Dec 28, 2012 | 01:26 PM
MTarry's Avatar
I believe throttle body.
Old Dec 28, 2012 | 01:33 PM
should be able to just swap it over then
Old Dec 28, 2012 | 05:03 PM
dirty19's Avatar
Ridin Dirty in Cali
^ I used my stock CX harness with my B18B, and all is right with the world!
Old Jan 1, 2013 | 06:53 PM
MTarry's Avatar
alright sweet! i just needed a second opinion just to know for sure. I'll probably do that but then il need another one to put back on to my d15b8 to sell the engine
mien_civic715
Aug 22, 2010 01:36 PM
danielblushtein
Jun 2, 2010 05:31 AM
eg93LS
Jun 10, 2009 08:51 PM
LS94tegra
Oct 13, 2008 05:17 PM
BlueRex1020
Mar 17, 2007 09:28 PM
