New problem? Trunk Leak
Old 04-15-2012, 05:05 PM
Kustom X's Avatar
Default New problem? Trunk Leak
trunk is leaking in my 96 civic. I have followed it to a spot by the trunk lid left arm. but dont know where its starting. checked seal around trunk but thats not it. anyone else have this problem?
Old 04-15-2012, 06:17 PM
NotAJDMFanBoy's Avatar
Default Re: New problem? Trunk Leak
Sure the seal is good? Wipe it with Armorall or silicone spray. Sometimes seals get kinda dried out and don't want to seal nicely. Plus that will keep them from sticking in the winter. Get a younger sibling/friend to climb in the trunk with a flashlight and pour water over the trunk. There's a chance it could be the vent thing under the bumper on the driver's side.
Old 04-15-2012, 06:19 PM
motegicivic's Avatar
Coupe or sedan? DX or EX?
I am willing to bet it is the run channel the factory seam sealer fails.
Old 04-15-2012, 06:24 PM
Retired Moderator
EsotericImage's Avatar
^^That or the sunroof tubing came out
Old 04-15-2012, 06:35 PM
leecivic's Avatar
Have the same problem on my 99 coupe DX. Fold the seat down and get someone to run water over the trunk with the water hose. If you have a sunroof, check the drains for clogs.
Old 04-15-2012, 08:21 PM
furious94ls's Avatar
Had this same problem on my EX coupe. Sunroof drain tubes were fine, trunk seal was fine. Masked off the paint and sprayed ruberized undercoat in the channel, and under the rear window. Leak fixed.
Old 04-16-2012, 09:54 AM
How did you spray under the window? or you mean the channel right under the window?
Old 04-16-2012, 11:08 AM
JDMxTai's Avatar
I had the same problem to but, it was because when I bought someone wreaked it so, the gas fill hole had a big whole that leaked rain water in.
Old 04-16-2012, 02:42 PM
There is a small opening under the rear window in both corners. I took the straw and sprayed it in/under there. I think the seams in the welds get weak/worn and causes leaks. I only did a light coat along the entire channel. The trunk stays 100% dry now.
Old 04-16-2012, 04:08 PM
You are talking about the the little hole up the corner, I think that was there for water drainage from the window molding.
I used silicone in that channel and the corner etc, might still leaked, it is better now though.
Old 01-01-2013, 10:56 PM
MO Problems's Avatar
My EX trunk was taking in water as bad as the Titanic! I havent had time to check up on it yet though!
weil186
08-03-2007 10:19 PM
foomashoo
04-23-2007 08:42 PM
wonton2049
11
12-11-2005 05:21 PM
POE
15
07-15-2005 12:45 AM
JnyStylz
14
04-25-2004 09:34 PM
Quick Reply: New problem? Trunk Leak
