eg b16 wont crank
hey honda-tech i got a eg sedan with a b16 swap and it currently isnt cranking. everything works like dash,headlights,interior lights. i thought it was a dead battery but i got it checked at autozone and they charged it to full and said its all good. when i turn the key to start i hear a clicking noise in the engine bay but not every time i try to start. do you think its a starter issue? do you think i should just remove it and let autozone test it or can this be a different problem? thanks
So describe the rest of the symptoms.
Fuel pump prime?
Just a click? or sometimes no click.
Definately get the starter checked out.
You also might want to check the engine ground wires, expecially the one from the tranny to the fender well.
Fuel pump prime?
1) Clean and tighten the G3 transmission ground wire connections on the transmission and chassis.
2) From the + battery post, run two wires, one to the starter solenoid and one to the starter motor. If the starter does not crank, replace it.
stevanrk
Jan 8, 2011 03:48 PM
dingusjt
Nov 30, 2004 11:44 AM
