Help! searched EG won't start b16
As the title states i have a problem with my car, its fully tucked my wires are all done right solder all the wires, everything is grounded. And all the lights work, fuel pump primes, everything works but after changing out my exhaust system i tired to start it up and it won't start.
-everything is plugged in sensors and all
-Starter isn't clicking when turn key all the way
-tried new starter off a running car still no click?
-tried new ecu off a buddy's running car as well nothing.
-But i can hear a relay clicking inside the car under the steering colum what can that be? its like making a clicking noise? is it a starter relay that has gone bad?
-also the car started before all this happened i'm clueless on what to do please help me out.
Wiring harness was done by chasebay.
I'm not Rick!
Re: Help! searched EG won't start b16
chasebays....errrrr
is the starter getting power for sure? ground?
is your battery good? any cel?
your relay goes bad usualy it clicks and cranks but no fuel
everything is grounded i double checked everything, my battery is good got it tested at my work place, and the only cel it was throwing was code 3 which is map. the car gets fuel but i'm getting nothing from my starter at all!!!!
ILUVTEC
03-20-2010 01:31 PM
soulassasincc
04-06-2006 03:50 PM
