reverse idler shaft bolt
i need the overall size of the reverse idler shaft bolt on b-series manual transmission??i lost it or never had it?and dealer has no good pics of it and told me they dont exist??i get no respect!
Are you talking about the Change Holder Assembly bolts, or the Reverse Shift Holder bolts?
Found all of this on http://www.hondaautomotiveparts.com. They actually show you the diagram for ordering parts. They're a legitimate dealership, and give good rates on parts.
If you're talking about the Reverse Shift Holder bolts...
CIVIC - 2000 - 2DR SI - KA5MT - MT SHIFT FORK (DOHC)
90028-PB6-010 006 002 BOLT, SPECIAL (6X22.5) 3.76 2.63
You need two.
If you're talking about the Change Holder Assembly...
CIVIC - 2000 - 2DR SI - KA5MT - MT SHIFT ROD - SHIFT HOLDER (DOHC)
90028-PB6-010 012 002 BOLT, SPECIAL (6X22.5) 3.76 2.63
You need two.
95701-06016-08 019 001 BOLT, FLANGE (6X16) 0.80 0.56
You need one.
You need two.
You need two.
You need one.
no, i was talking about the reverse idler shaft bolt on the top of transmission its next to the motor mount posts on top passenger side its a 14 mm but i need length and width it is an external bolt that is accessible from outside of outer case of transmission! sorry about if i did not make it clear in my post!
yeah its 26 and 17 in the last diagram !thank you! is this bolt size 10-1.50-35mm? can anybody confirm the size of this bolt?no help from acura and honda dealership!
95EG2
Feb 28, 2010 03:38 PM
allmotorls95
Sep 10, 2002 09:00 AM
