reverse idler shaft bolt
i need the overall size of the reverse idler shaft bolt on b-series manual transmission??i lost it or never had it?and dealer has no good pics of it and told me they dont exist??i get no respect!
Re: reverse idler shaft bolt
Are you talking about the Change Holder Assembly bolts, or the Reverse Shift Holder bolts?
Found all of this on http://www.hondaautomotiveparts.com. They actually show you the diagram for ordering parts. They're a legitimate dealership, and give good rates on parts.
If you're talking about the Reverse Shift Holder bolts...
CIVIC - 2000 - 2DR SI - KA5MT - MT SHIFT FORK (DOHC)
90028-PB6-010 006 002 BOLT, SPECIAL (6X22.5) 3.76 2.63
You need two.
If you're talking about the Change Holder Assembly...
CIVIC - 2000 - 2DR SI - KA5MT - MT SHIFT ROD - SHIFT HOLDER (DOHC)
90028-PB6-010 012 002 BOLT, SPECIAL (6X22.5) 3.76 2.63
You need two.
95701-06016-08 019 001 BOLT, FLANGE (6X16) 0.80 0.56
You need one.
You need two.
You need two.
You need one.
no, i was talking about the reverse idler shaft bolt on the top of transmission its next to the motor mount posts on top passenger side its a 14 mm but i need length and width it is an external bolt that is accessible from outside of outer case of transmission! sorry about if i did not make it clear in my post!
yeah its 26 and 17 in the last diagram !thank you! is this bolt size 10-1.50-35mm? can anybody confirm the size of this bolt?no help from acura and honda dealership!
