b16 burning oil...help
Old Dec 25, 2012 | 11:57 PM
ribal_gh's Avatar
Default b16 burning oil...help
Hello guys,
It has been more than 1 year that bewteen every oil change, my engine burns about 1.5 qaurts of oil. (certainly im adding oil)
I change oil every 2000 miles.
No oil leak and No smoke coming out of the muffler.
So where is that oil going !!!!
Old Dec 26, 2012 | 01:25 AM
jbpnoman's Avatar
Default Re: b16 burning oil...help
Losing a quart and a half every change might not blow visible smoke. Two diagnostic things you can do to help find the source of the problem: Clean the entire motor and engine bay with some engine degreaser, and do a leakdown test. After cleaning with the degreaser, it will be easier to spot any possible micro-leaks you might not notice through the normal engine grime, and the leakdown test will help identify anywhere the oil might be leaking/burning in your engine.
Old Dec 26, 2012 | 01:56 AM
ribal_gh's Avatar
Thanks man,
So if one of the cylinders show a leak higher than 20% ,then it is probably the pistons rings are bad? or thats not correct?
Old Dec 26, 2012 | 02:06 AM
jbpnoman's Avatar
either the rings, or the valve seals. A leak in either would cause burning oil, and a leak as small as yours might not show in the exhaust.
Chris dc2
May 2, 2019 01:00 PM
serjey15
Dec 4, 2010 07:20 PM
kusgan
Sep 20, 2008 08:57 PM
94DB8
Feb 20, 2008 04:28 PM
Jeff
Apr 30, 2005 04:01 PM
