2000 ex - D16Y8 bottom end is trashed
I have a 2000 civic ex bone stock d16y8 that the bottom end is trashed.
I have access to a d16y7 what does it take to swap from a y8 to a y7.
Also I've came across a lot of sites that sell engines who do you recommend and who do you stay away from?
I'll be a little more specific the y8 is coming out of the car.
The y7 is going in.
I want to reuse the y8 harness and auto trans that is already in the car.
What ecu, intake, distributor etc?
The y7 is going in.
If you loved me, you'd all sell me your magic cards to me today
Does this help at all?
D16Y7
Found in:
1996–2000 Honda Civic DX/VP/LX/CX
1998–2000 Honda Civic Special Edition – SE/EX(Canada)
1996–1997 Honda Del Sol S
1996–1997 Honda Civic Coupé LSI
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Compression: 9.4:1
Power: 106 hp (79.0 kW, 107 ps) at 6,200 rpm
Torque: 103 lb·ft (140 N.m) at 4,600 rpm
Redline: 6,800 rpm
Rev-limiter: 7,200 rpm
Valvetrain: SOHC (4 valves per cylinder)
Fuel Control: OBD2-a MPFI
Head Code: P2A-2
Piston Code: P2E
ECU Code: P2E
Cam Gear: 38 Tooth
D16Y8
1.6 litre 16-Valve, SOHC VTEC Also available in New Zealand under the code D16Y6
Found in:
1996–1997 Honda Del Sol Si (US)
1996–2000 Honda Civic EX (US, UK)
1996–2000 Honda Civic Si (Canada)
Redline: 6,800 rpm
Rev Limit: 7,200 rpm
ECU Code: P2P
Piston Code: P2P
Fuel Control: OBD2-b
VTEC switchover: 5,600 rpm
Power: 127 hp (95 kW) at 6,600 rpm
Torque: 107 lb·ft (145 N·m) at 5,500 rpm
Compression: 9.6:1
Deck Height: 8.347 inches
Rod Length: 5.394 inches
Curb weights:
96-98 coupé (MT/AT): 1,116 or 1,132 kg (2,460 or 2,496 lb)
99-00 coupé (MT/AT): 1,140 or 1,161 kg (2,513 or 2,560 lb)
96-98 sedan (MT/AT): 1,142 or 1,165 kg (2,518 or 2,568 lb)
99-00 sedan (MT/AT): 1,140 or 1,162 kg (2,513 or 2,562 lb)
D16Y7
Found in:
Compression: 9.4:1
Redline: 6,800 rpm
Head Code: P2A-2
Piston Code: P2E
ECU Code: P2E
Cam Gear: 38 Tooth
D16Y8
Found in:
Redline: 6,800 rpm
ECU Code: P2P
Piston Code: P2P
Compression: 9.6:1
Curb weights:
You'd need to source a auto DX ECU. but everything else is bolt on, however you may run into a little issue with the air pump thing 99-00 got.
Slight compression difference.
2210a
Jun 9, 2016 07:03 PM
