idle issue
Old Dec 25, 2012 | 08:50 AM
hun8504's Avatar
Default idle issue
I have a 94 civic ex with the d16z6
Every morning I start my car it idle between 2000-2500 rpms. What could cause this.
Also when I press on the gas after shifting I can hear a whistle/hissing sound
Old Dec 25, 2012 | 08:57 AM
grumblemarc's Avatar
The Grumpiest
Default Re: idle issue
Since when?
Clean IACV & FITV.
Old Dec 25, 2012 | 11:01 AM
scottied15's Avatar
air leak? check your hoses, the throttle body gasket and IM gasket.
do you have an aftermarket intake? if so, that could be the hissing/whistle your hearing....
after it warms up where is the idle at?
and like grumblemarc said, your fitv could need adjusting.
Old Dec 25, 2012 | 04:43 PM
Emeraldbomber's Avatar
I have an aftermarket intake and that hissing sound is from the intake dont worry. Clean/ adjust the fitv and report back.
Old Dec 26, 2012 | 02:17 AM
whiteboy1330's Avatar
i am having the same problem with the b18c with type-r head in my eg..it doesnt do it all the time..only cold when i start it(3000) RPM...and while sitting..
Old Dec 26, 2012 | 06:03 AM
hun8504's Avatar
Yes I do have a aftermarket intake..but the whistle noise is not from that cause I put the stock intake back on the see if it made the whistle noise and it did.
After a minute or so it idles it 500 rpms
Old Dec 26, 2012 | 07:39 AM
sounds like a simple fitv adjustment and cleaning like everybody else said.........
Also there is a little breather on the transmission and when you clutch in it pushes air out of it making a whistling noise.
Old Dec 26, 2012 | 09:37 AM
backyardbuilt92's Avatar
Definitely iacv/ fitv related. Should idle at/around 1700-2000 on first startup and calm down to 750-900 after at operating temperature
h-o-n-d-a
Aug 3, 2009 05:15 PM
Jaydium
Mar 28, 2006 07:18 AM
SimplyTron
Jan 26, 2006 08:19 PM
mike93eh
17
Dec 15, 2004 06:48 PM
Vp Special K
26
Nov 9, 2003 10:24 AM
