idle issue
idle issue
I have a 94 civic ex with the d16z6
Every morning I start my car it idle between 2000-2500 rpms. What could cause this.
Also when I press on the gas after shifting I can hear a whistle/hissing sound
Re: idle issue
air leak? check your hoses, the throttle body gasket and IM gasket.
do you have an aftermarket intake? if so, that could be the hissing/whistle your hearing....
after it warms up where is the idle at?
and like grumblemarc said, your fitv could need adjusting.
Re: idle issue
i am having the same problem with the b18c with type-r head in my eg..it doesnt do it all the time..only cold when i start it(3000) RPM...and while sitting..
Re: idle issue
Yes I do have a aftermarket intake..but the whistle noise is not from that cause I put the stock intake back on the see if it made the whistle noise and it did.
After a minute or so it idles it 500 rpms
Re: idle issue
sounds like a simple fitv adjustment and cleaning like everybody else said.........
Also there is a little breather on the transmission and when you clutch in it pushes air out of it making a whistling noise.
h-o-n-d-a
08-03-2009 05:15 PM
Vp Special K
26
11-09-2003 10:24 AM
