front sway bar question
Old Dec 24, 2012 | 01:14 PM
digitz's Avatar
Default front sway bar question
does anybody make a 24mm front sway bar for a 99-00 SI?
Old Dec 24, 2012 | 01:28 PM
grumblemarc's Avatar
The Grumpiest
Default Re: front sway bar question
What's wrong with the one you have? It's 26mm.
Old Dec 24, 2012 | 01:32 PM
JaySi's Avatar
Are you sure your not looking for a 24mm rear sway bar the front is 26mm stock i dont know anyone to switch the front one
Old Dec 24, 2012 | 02:36 PM
98civdx's Avatar
Master Detailer
You could put a 24mm front on it, if you wanted to.
But you'd have to switch the lower control arms, shock forks, and endlinks out.
Old Dec 24, 2012 | 03:53 PM
digitz's Avatar
yeah I guess I'll have to swap out the front lca's for ex ones. the reason for this is that I already have a asr 24mm SB kit for the rear and I want to even out the car with the same size in the front or at least a little smaller i'm shooting for a neutral balanced car or a little oversteer 26 in the front will give me more of a understeer characteristic. Thanks for the feedback.
Old Dec 24, 2012 | 03:54 PM
The Grumpiest
Then get stiffer springs in the back.
Old Dec 24, 2012 | 03:59 PM
98civdx's Avatar
Master Detailer
What are the spring rates?
Old Dec 24, 2012 | 10:35 PM
jbpnoman's Avatar
Same size != same handling dynamics. A neutral suspension won't have the exact same sized parts front and rear.
Old Dec 25, 2012 | 08:52 AM
EsotericImage's Avatar
Retired Moderator
I thought suspension techniques made a 26mm.. not 100% positive tho
or ST suspensions. IDK what name they use anymore
Old Dec 31, 2012 | 01:07 AM
JaySi's Avatar
If for some reason u switch all those parts I'd be intrested in buying the forks
Also I just swapped the k member and rack, hubs ect... In my 96 ex to 99 GSR stuff and that was a huge upgrade to me , my turning radius is noticably tighter and it feels like it rides smoother too I recommend it to all ek owners and on top of it all I don't need to find a 99/2000 Si Tbracket to dump my typeR swap in!!!!!!!
I also have a Type R swap to let go!!!!
K20egcw
Suspension & Brakes
14
Sep 5, 2012 07:59 PM
kccord
Jul 7, 2009 03:15 PM
zippo1130
15
Jan 15, 2008 07:45 PM
honda_coupe
10
Mar 19, 2007 09:59 PM
agent marlon
Dec 27, 2001 02:16 PM
