Is there room for two mufflers under an EK Civic?
Old Dec 20, 2012 | 04:38 AM
civic_jason's Avatar
Default Is there room for two mufflers under an EK Civic?
In preferably a single pipe exhaust setup. I imagine if I split my pipe into a dual exhaust there is room on both sides for a muffler but that's not really the look I'm shooting for because I want a very stock look.
Of course my goal is a quiet exhaust setup without spending $200+ for a stupid muffler for a commuter car that's not choked out of power due to an overly restrictive muffler.
Old Dec 20, 2012 | 04:42 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Is there room for two mufflers under an EK Civic?
Have you actually got under your car to look for yourself? Seriously.
Old Dec 20, 2012 | 04:52 AM
TypeRfit's Avatar
RESIDENT
Haha. Grumble sometimes your common sense is on point.
Old Dec 20, 2012 | 04:59 AM
I have seen my car on a lift while at an exhaust shop so yes I have. I'm still uncertain because I could not measure it but from my view that day it looks like there is possibly room. My car is in the shop getting the B20 and AUTOmatic installed as we speak so I can't just go out and check right now.
Seriously, does anyone have any constructive answers for me? Preferably someone who has done it or tried it?
Thanks,
Jason
Old Dec 20, 2012 | 05:39 AM
B_Swapped93's Avatar
why do you want a dual muffler setup ? leave that for mustangs and camaros it looks horrid on hondas(except the S2K)
Old Dec 20, 2012 | 05:52 AM
Oh no I want inline mufflers...probably one where the resonator should be. Everything I read says that resonators just change the pitch and don't help quiet things down so I'm thinking a second muffler is my better option.
The only reason I'm half way considering a dual exhaust is that the guy that does welding at the exhaust shop has an ek Civic and he has dual exhaust with very small pipes and it so inconspicuous it doesn't look bad.
Old Dec 20, 2012 | 07:10 AM
I called the muffler shop that had it on the lift and spoke to the guy that had the dual exhaust. He said there was no room for mufflers any where else but the back of the car and he also said he had two mufflers and two resonators per pipe.
Old Dec 20, 2012 | 01:16 PM
The Grumpiest
So you already knew the answer to this question? You know the guy that has it done and you're asking us if it can be done and not asking him how he did it?...why?
Old Dec 20, 2012 | 01:30 PM
Caddiman's Avatar
back in the fast and furious days, i had a 98 and a 95 coupe with dual exhaust.........its possible....I wouldnt do it again, but hey, its your car. If you like it, thats all that matters bro. who cares what others think
Old Dec 20, 2012 | 02:23 PM
canadaek's Avatar
check out libertariat build thread he has an h2b and is running some mufflers in line
Old Dec 20, 2012 | 02:54 PM
Caddiman's Avatar
ohhhh, he means 2 mufflers in line with each other? hmmm, why doe
Um no he has dual exhaust I want inline mufflers...dual was tempting at the time of this post but that temptation has past with some extra thought plus I don't think it would help quiet my exhaust.
Old Dec 20, 2012 | 02:58 PM
Are those not resonators? Resonator or muffler did they make the car quiet?
Why doe ? I want to hear engine over exhaust not the other way around during my commute home.
Old Dec 20, 2012 | 02:59 PM
EsotericImage's Avatar
Retired Moderator
why not get your exhuast on and go from there.. this is the 3rd or 4th exhaust question in a month.
your not going to know how good/bad it sounds until you try it. since you want to use what you got is understandable. but we cant answer these questions just cuz your not using the tried and true method.
So weld it up and see what happens, then either keep it or change for whats proven to work.
GoLowDrew
Oct 25, 2010 08:30 AM
rico892002
Jun 17, 2009 07:33 PM
adam_mcd
Jan 11, 2006 06:34 PM
BiziggumS
13
Aug 29, 2004 03:53 PM
atc5
Jun 15, 2004 01:19 AM
