V-tec Malfunction
Old Dec 17, 2012 | 11:14 AM
DailyEk's Avatar
Default V-tec Malfunction
I've got a 98 Civic HX with a Mini-me I haven't seen before, so I'm pretty sure the guy that did it before I got the car wasn't properly thinking. It's a d16y5 Block with a y8 head. If I drive the car under normal conditions, no heavey throttle, no 'vtec just kicked in yo', the CEL and problems won't start. However, I recently ran the car on a circuit track for a toys for tots thing and after cracking vtec, high rpms, and alot of speed, my CEL popped on and the car would not go over 4krpm, which I'm assuming is when vtec cracks. After the laps were done, I pulled the code and got Vtec malfunction. But here's the weird part, I turned the car off, turned it on and I was able to go over 4krpm again. I checked oil, it was at max, I checked wires, none of them are shoot/burnt/or cut. I'm going to check a new ecu and vtec solenoid off my friends car, but before all that, any advice?
Old Dec 17, 2012 | 11:21 AM
JuggerNaut-CTR's Avatar
Default Re: V-tec Malfunction
Oil pressure switch or the solenoid is where Id start...most likely not the ecu, but doesnt hurt to try
Old Dec 17, 2012 | 11:25 AM
97_ek_coupe's Avatar
Make sure there is no gunk buildup on the solenoid. Also, vtec for y8 kicks in at 5600rpm
Old Dec 17, 2012 | 11:30 AM
DailyEk's Avatar
I know normally y8 Vtec kicks in at 5600 but the way it was acting at 4000 kind of had me guessing that the maybe the ecu was chipped or flashed so the vtec kicked in quicker? But I'm just kind of at the troubleshooting process cause I've never seen a mini me with a y5 block.
Let's hope it's something small and not expensive like the solenoid.
Old Dec 17, 2012 | 11:35 AM
Say it is the solenoid....pick and pull junkyards will have em cheap
Old Dec 17, 2012 | 11:38 AM
DailyEk's Avatar
Not up here, Honda's are picked clean in minutes. I know a few people that might be willing to sell them but I'd still rather it be something less expensive or annoying to find.
Old Dec 17, 2012 | 11:46 AM
Who wouldn't? lol...
Old Dec 17, 2012 | 12:10 PM
HondaPartsHero's Avatar
Technical Hero
What ECU are you using?
Old Dec 17, 2012 | 12:29 PM
blkSi's Avatar
CEL will go back off once you turn vehicle off then back on (for Vtec malfunction). Won't come back on until vehicle engages vtec again. (like, 99% sure)
Old Dec 17, 2012 | 04:07 PM
beecee18's Avatar
Nice try though
leondx
42
Oct 7, 2019 02:28 PM
dwils
Oct 28, 2012 11:04 AM
chinoslines
Jun 30, 2010 08:47 AM
Corksil
Dec 17, 2009 02:50 PM
4drsedaneg
Sep 26, 2004 03:54 PM
