The only stupid question is the one not asked! Proper way to check engine oil?
Old Dec 17, 2012 | 04:46 AM
adamn92's Avatar
Default The only stupid question is the one not asked! Proper way to check engine oil?
So I just read a conflicting report on something I've been doing a certain way since I've been driving my car.
I read this morning when checking your oil on a D-Series engine you should check it while the engine is cold?
I have been lead to believe since I started driving in 1996 you warm the engine, then let it sit for 5 minutes, then check the oil level.
I read this from a pretty reputable source which is why I pose this new thread.
Whats your thoughts? I know I get completely different levels when I check the oil warm/cold?
Old Dec 17, 2012 | 05:29 AM
Lizardslap's Avatar
Default Re: The only stupid question is the one not asked!
it dont really matter just keep the oil between the 2 dots
there probably getting at it ending up back in the pan the oil that goes up into the head and what not but there better be enough to have some on the stick even if its running
Old Dec 17, 2012 | 05:40 AM
Former User's Avatar
Default Re: The only stupid question is the one not asked! Proper way to check engine oil?
This^
Old Dec 17, 2012 | 06:27 AM
dirty19's Avatar
Ridin Dirty in Cali
Check the oil cold while on a level surface.
Old Dec 17, 2012 | 07:40 AM
jbpnoman's Avatar
Oh the stories I have of friends with ramped drive ways checking their oil...or checking it while the front is on jack stands.
Yes, I have stupid friends.
Old Dec 17, 2012 | 08:05 AM
HondaPartsHero's Avatar
Technical Hero
That's interesting because the owners manual says "check the engine oil a couple of minutes after shutting off the engine". Now this is mainly due to the fact that you need to allow the oil to go to the bottom of the pan but also assumes you can check it when hot or warm as well.
Old Dec 17, 2012 | 12:54 PM
warnerbryan7's Avatar
there's two ways i like to check oil. the first way is in the morning before i turn on the car. 2nd, is turn on the car and let it idle for a few seconds, shut it off, pull out the dipstick and wipe it clean. put the dipstick back in and check the oil level. make sure the vehicle is on flat surface.
Old Dec 17, 2012 | 01:23 PM
adamn92's Avatar
Originally Posted by RonJ@HT
This^
Then I really was low on oil
thanks guys...
Old Dec 17, 2012 | 01:40 PM
Technical Hero
The FSM confirms this as well which would indicate either way. I don't think oil expands enough to throw off the reading by any substantial amount like transmission fluid. Just make sure to give it enough time to drain back down (a couple of minutes) if you are checking it after driving.
BrokdwnCrx
Honda S2000
Jul 5, 2003 11:09 AM
Qwikrex
Dec 11, 2002 03:05 PM
JMinSi2000
Aug 15, 2002 07:49 PM
B18Redline
Jun 10, 2002 11:35 AM
Rah Rah
Feb 1, 2002 10:19 PM
