When to check oil level?
Are you supposed to read the dipstick with the engine fully cold, or are u supposed to start it first and then turn it off and check? When cold, my dipstick will be at the half mark, but after being started it will be low because the oils been circulated. What's the correct way to read oil level?
New User
Re: When to check oil level? (B2FiNiTY)
i have always checked my oil aftern the motor has reached operating temperature and then let sit for a few minutes
this is what the manual says to
lets hear more inputs on this
Best when cold. Fill it up to the dot when cold too
Re: When to check oil level? (benmasters)
Same here....I believe the reasoning is that by the time the engine has "cooled", the oil has drained down into the oil pan suffiently to be able to take a more accurate measurement of what is actually in the engine.
Oh, and I check the level Every time I drive it,,, I'm Not kidding either...
A.
Re: When to check oil level? ([VTEC]TL)
I check my oil every time I get gas, which is every 3-4 days. I wait until about halfway through filling up the car until I check the oil, check it ~3 times in the event that there is still some oil that has been accounted for.
Austin
Austin
New User
Re: When to check oil level? (Austin)
Austin
Austin
Austin
Austin
Me too
cannot hurt being checked often
Re: When to check oil level? (IntegraGSR23)
do you guys think that the oil has enough time to drian after only a few mins? I find the only readings i trust are on level ground after like an hour of sitting.
GTX 5w30 5-qt. jugs were on sale at wal-mart the other day...
Re: When to check oil level? (Aleph)
you guys probably think you burn oil because so much of it disappears and ends up on a rag.
i've checked it 60min after driving and when the car has sat all night and gotten the same readings, so i just check it in the mornings once a week or so.
How much was the GTX?
do you guys think that the oil has enough time to drain after only a few mins?
I once started my car realised i needed to check oil so turned her off again and left her five minutes and checked, she was half way on oil so i topped her up.
Then that evening after she hadnt been running for at least an hour i checked it again and it was way over! had to go and loosen the sump plug to let some out
[Modified by benmasters, 8:03 PM 12/11/2002]
Re: When to check oil level? (1GreyTeg)
I saw a 5qt jug of GTX for $5.88 at Kmart yesterday. That's a deal.
adamn92
12-17-2012 01:40 PM
Comptech98GSR
07-10-2002 12:54 PM
B18Redline
06-10-2002 11:35 AM
Blue teg
12-04-2001 06:07 AM
