Oil question
Old Aug 15, 2002 | 07:37 PM
JMinSi2000's Avatar
Default Oil question
I know that when you're turboed you should check your oil everyday and make sure the oil level is right. Should you check the oil when the engine is cold or hot?
Old Aug 15, 2002 | 07:49 PM
Brian_92GSR's Avatar
New User
Default Re: Oil question (JMinSi2000)
Just make sure you always do it at the same time (like only check it when it's cold). If the level is fine when it is cold and you check it when it is hot there won't be as much in the pan.
gwarfare
Feb 19, 2013 01:58 PM
adamn92
Dec 17, 2012 01:40 PM
motegicivic
Oct 13, 2011 05:59 PM
kevin85193
Jun 12, 2005 11:42 AM
B18Redline
Jun 10, 2002 11:35 AM
