actuator diagram (keyless trunk pop)
Old Dec 15, 2012 | 03:58 PM
j13's Avatar
j13
Default actuator diagram (keyless trunk pop)
I have a 96 integra, I recently installed a viper alarm and everything works flawless. I am having trouble hooking up an actuator to pop the hatch. I have tried multiple diagrams but nothing has worked.
my second channel AUX wire is Red/White (-) 200mah, which pin do I hook this up to on the relay? ground? 12v?
thanks in advance
Old Dec 16, 2012 | 03:10 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: actuator diagram (keyless trunk pop)
85- alarm. 86-12 volt fused. 30- 12 volts. 87-acurator. Ground other wire of acurator.
Old Dec 16, 2012 | 05:26 PM
j13's Avatar
j13
thanks man! I'll try tomorrow
Old Dec 20, 2012 | 03:37 PM
j13's Avatar
j13
didnt work, the relay doesn't click
Old Dec 20, 2012 | 07:59 PM
Either you did not give it 12 volts or the alarm did not kick out the ground trigger. You have to hold the trunk button on the remote for 3 seconds
Old Dec 21, 2012 | 10:24 AM
j13's Avatar
j13
it works perfect the fuse wasnt blown but it had a hair line crack so I couldn't tell it was broken! thanks man!!!!
hondahustle
Audio / Security / Video
Nov 17, 2013 02:50 PM
j13
15
Jan 8, 2013 05:52 PM
arw321
Sep 5, 2003 12:25 PM
cyvic
Aug 3, 2003 06:51 PM
Ludeboi
10
Oct 7, 2002 05:14 PM
