I want the horn to honk with alarm, but no alarm output
I have a 96 integra, with a Viper 350 Responder installed, I want the horn to honk in a pusle with the alarm, but this alarm doesn't have a horn honk output wire.. anyway I can wire up a relay to honk it in a pulse? I need wiring diagram for this feature
thanks in advance!
thanks in advance!
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Re: I want the horn to honk with alarm, but no alarm output
Makr sure you diode isolate it cause if you turn on the parking lights the horn will sound solid.
Old Fart
Ground to #30 of SPDT relay.
#87 of relay to horn trigger lead, [gray or blue/green @ steering wheel harness].
Alarms park light output to #85 of relay, [and to park lights].
H1/12 orange [GWA] of alarm to #86 of the relay, horn will only honk if alarm is armed. 94
I use the black white wire dome light output on the alarm to the #85 and the brown siren output wire onto #86 instead of the orange wire so u don't have to use diodes
can't use that wire... I think all it does is turn on the dome light for 30seconds once armed/disarmed ..people would hate me lol
Old Fart
No diode is needed if the orange lead is used, the orange lead is a ground only when alarm is armed GWA= ground when armed. 94
horn lead to#87
Alarm park light output to #85
I can use this without a diode? if so I'll try thus tomorrow
On the 350 it has a relay for the starter kill, if thats being used then u gonna need diode, I never hook up the dome light output bc my truck dome comes on whenever it's unlocked so I use that
Ground #30
Horn #87
Dome light output #85
Siren output #86
When the alarm goes off it'll give u the honk honk
Ground #30
Horn #87
Siren output #86
It *does* have a horn-honk output -- See the manual. You can configure the siren output through programming as a (-) output to connect to your horn instead of a siren. This is how I use the R350 -- I don't have siren installed, at all.
Ugh --- Nevermind.
You want the horn to operate *w/your siren*. Disregard what I said.
I have a Responder 350 in a 2K Civic.
Old Fart
You can download the install guide here... http://www.the12volt.com/installbay/...iper+responder programing starts on page 20, the siren/horn is in Menu #2 - Advanced Features, [2-1].94
