Remote start, not starting ??
Old Dec 21, 2012 | 01:11 AM
DOMAN!EJ8's Avatar
Default Remote start, not starting ??
Hey guys, I have a 1997 Civic, with Clifford 50.5x, barely used the remote start, and noticed recently that it doesnt work(it used to work). It attempts to start ONCE, but it doesnt crank, just clicks. The purple/white tach wire is connected to the rpm blue wire on the cluster. I relocated the purple/white wire and connected it to one of the injector leads, and i programmed the tach, same result.
I tried the shutdown diagnostics (http://www.directeddealers.com/manua..._05-06post.pdf, page 53) and the LED flashed 6 times. Which shows, (-) Shutdown (H3/4 GRAY) or (+) Shutdown (H3/3 BROWN)
so I double checked the brown brake wire, it was T tapped into the green brake line wire, i removed the T tap and connected it, tried remote starting, and the car CRANKED and it didnt start(my timing?? was delayed due to tuning), but it did this THREE times. I tried pressing it again, it went back to not cranking at all again.... thoughts?
Old Dec 21, 2012 | 02:48 PM
DOMAN!EJ8's Avatar
Default Re: Remote start, not starting ??
help?
Old Dec 21, 2012 | 03:21 PM
fcm's Avatar
fcm
Old Fart
Check your hood pin wire, H3/4 gray.
Have you reprogramed tach?
To learn the tach signal:
1. Start the vehicle with the key.
2. Within 5 seconds, press and HOLD the Valet/Program switch.
http://www.directeddealers.com/manua..._05-06post.pdf 94
Old Dec 21, 2012 | 09:46 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
A faulty brake light bulbs or in the brake wiring. If your running a ems remote start does not like this. In the likes of aem, motec, neptune cause of the delay of fuel pump. I strongly advise againt remote starting a agressive tuned car.
Mikal92
Audio / Security / Video
33
Mar 30, 2009 08:02 PM
socallmechris
Jan 20, 2008 08:54 AM
egcivic611
15
Feb 14, 2006 01:27 PM
5genhatch
Aug 7, 2005 06:04 PM
huffer427
Jul 9, 2004 05:30 PM
