Lost Alarm Remote!!
Old Aug 1, 2003 | 07:08 PM
cyvic's Avatar
Default Lost Alarm Remote!!
My uncle has a 94 Integra and he lost his alarm remote. He can't start his car. He asked me to help him but I didn't really know what to do. Should we try to put everything back to stock? I don't know what alarm he has. Any suggestions would help.
Old Aug 2, 2003 | 05:10 AM
Xsi's Avatar
Xsi
Unless there is a disable switch somewhere you will probably have to remove the whole alarm and get another. In the mean time you can try to disable the immobiliser.
Old Aug 2, 2003 | 06:56 AM
rjr162's Avatar
Default Re: (Xsi)
you should be able to just pull the fuse for the alarm and bypass the immob as said above. Typically they just cut the starter wire and wire a relay inline. either cut the relay out and hook the starter wire back together, or use some 12 guage or so wire to jumper the two ends leaving the relay in, so if he ever gets the remote again you can just cut the jumper wire and tape it so the alarm functions normally again
Old Aug 2, 2003 | 12:04 PM
queez's Avatar
Default Re: (rjr162)
hey what kind of alarm is it?? does it have a valet switch anywhere? send me an IM maybee i can walk you through it
Old Aug 3, 2003 | 06:51 PM
tegmech's Avatar
don't cut anything!!!! all you need to do for now is unplug the brain of the alarm. Most alarms have a harness that has two wires(black) that will need to be left in to be able to start the car. any questions pm me and i can tell you exactly what to do
GsDAteg
Audio / Security / Video
Mar 18, 2010 04:40 AM
918-Hatch
19
Oct 18, 2006 04:04 PM
arw321
Sep 5, 2003 12:25 PM
technine
Dec 17, 2002 08:54 AM
Weston
Jan 30, 2002 04:01 PM
